Battery monitors (1 Viewer)
DanielFord
3,020
3,086
OK peeps, need some input/reviews. After @eddievanbitz did all the work on my van, he said I could do with fitting a battery monitor to, erm, monitor the battery!!!
I've been doing some research, and I have kind of made a decision on purchasing a nasa bm2, it looks ideal, it supports my battery output, and is about the right size for someone who has really rubbish eyesight.
Does anyone have any words of waning, or better suggestions before I hit the buy button on flea bay?
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I don't have one, but I believe Eddie, and others, recommend the Victron battery monitor in preference to the Nasa model.
D
DanielFord
3,020
3,086
That has not come up in my searches, I will look into that one! Thanks
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I donr believe you Andy....you took something out ! ;)
Yes it was fitted in an un user friendly position inaccurate and ultimately ignored. If you understand battery voltage under load and with no load it's unnecessary
D
DanielFord
3,020
3,086
OK found it, looks a little too small for someone who is horrendously long sighted. I like things I can read without glasses, which means big numbers.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Take your pick
Good as any. You only need to understand that they are figures with no load on the battery
AND of course no battery charger! as that would not be relevant
Techno
Jul 28, 2010
15,475
20,756
May 2010
Anything below 50% state of charge is damaging to battery life long term. Always fully re charge as a matter of urgency
Techno
Jul 28, 2010
15,475
20,756
May 2010
Now my solar battery bank for my inverter may drop to 11.9 volts when its giving 150 amps but that isn't a worry as it does not reflect the state of charge and the fact that it will rapidly climb back to 12.6 plus (after inverter finishes) is the reassurance that I don't need a battery monitor to tell me the same
D
DanielFord
3,020
3,086
You see that's the info I am after, I want to know how much I am killing the batteries on the inverter, and whether I should forgo that extra capucino :D
Techno
Jul 28, 2010
15,475
20,756
May 2010
The bigger the battery bank the more smug you can be about not running out :LOL: but it's the voltage with no load that matters (y)
11,956
16,570
I find you develop a 'feel', based on voltage alone, about the state of the batteries. Anything else is interesting but not particularly helpful. The important thing is as Andy states above.
JeanLuc
3,304
2,199
Warwickshire
I guess the Victron unit is quite small at 2" diameter. Attached is another one recommended to me by Udo Lang of Schaudt. I haven't bothered to fit one and it may not be easily obtainable in the UK but offer the info in case it helps.
(I believe Grommet has experience of using both Nasa and Victron monitors - you might care to ask his advice).
  • LCD-Battery-Computer.pdf
