My battery monitor readings are not making sense? Anyone understand why these readings are being displayed.
What @Lorryman100 said.Two solar pannels. Not on hook up. One connected directly to leisure batteries and other into Sargent system. I don't understand why I'm bulk charging full batteries and why controllers are allowing 2.1 amps to go to full batteries.
I do not understand what you state.Was the 2.1 charge in the last charge it recieved ?
OK ! I now understand what your saying. However, I beleive you to be wrong. Solar is charging,as this is the only source of electrical input going to the batteries. This is confirmed by the 2.1 Amp reading being black in colour, if it was a discharge from the battery it would be in red. Not sure about the logic behind your ' won't see a charge in until the battery voltage gets to 13 v' statement as the shunt and monitor provide readings of the battery condition in real time regardless of their charge status.Solar is not charging so where is the charge coming from so its either the last charge that went in or a discharge if so you probably wont see a charge in until the battery voltage gets to 13 v
Joe
My Sargent control panel more or less is identical to the shunt readings with the exception of how full the batteries are as expressed as a percentage. Before fitting the shunt a volt meter confirmed the voltage display on my Sargent control panel was bang on. The controller on my Sargent system and on my suitcase solar panel are set for less acid as all my batteries are connected to the Sargent system and charger which had performed flawlessly since new. I have also confirmed the two controllers act independently from each other and overall very happy with the set up.I would check the voltage with a meter and disconnect a terminal and check the current as well that will confirm if your reading are correct.
I don't see why you need two separate solar regulators also are the regulators the type that reduce to a maintenance charge of around 13.8 volts once the batteries are charged. There are a lot of regulators that stay at 14.2-14.4v permanently once the batteries are chargedd if one of your regulators is doing that it would explain your readings..
Should have said before, inverters can play havoc with battery reading as you can get a lot spikes on the 12 volt supply.My Sargent control panel more or less is identical to the shunt readings with the exception of how full the batteries are as expressed as a percentage. Before fitting the shunt a volt meter confirmed the voltage display on my Sargent control panel was bang on. The controller on my Sargent system and on my suitcase solar panel are set for less acid as all my batteries are connected to the Sargent system and charger which had performed flawlessly since new. I have also confirmed the two controllers act independently from each other and overall very happy with the set up.
I can only assume it has something to do with my inverter being in use at the time the reading was taken.
I don't get that John. .. the 2.1 amps is a charging current...ie into the battery as measured by an inline shunt... the only way you can know what the load current on the system is is to know the total current flow from the controller ... and subtract the 2.1 amps from it...( ie the 2.1 amps been the balance available for charging )The inverter and other bits are drawing 2.1amps from the battery but the solar is replacing it immediately cancelling the drain.
No, the shunt shows current passing though it, it matters not where its going....in this case its powering the inverter.I don't get that John. .. the 2.1 amps is a charging current...ie into the battery as measured by an inline shunt... the only way you can know what the load current on the system is is to know the total current flow from the controller ... and subtract the 2.1 amps from it...( ie the 2.1 amps been the balance available for charging )
The current flow can only be one way at any time..
Andy.
cheers John, ill have a think about your example , but the problem I have atm is the shunt is capable of showing the direction of current flow... or at least the one I have wired to a ppm does.. its either a charging current or it shows as a negative value to indicate a discharging current..No, the shunt shows current passing though it, it matters not where its going....in this case its powering the inverter.
well its normal to place the shunt so that all connections made to the battery (both the load and charging sources ) go through it, otherwise whats the sense..?Depends were the shunt is though..
Between battery and load it cant show a charge current
Now that makes sense.But for a proper charge monitor you should be filling the glass through the same straw! The shunt should be the only connection to the battery. All charge and load connections should be done at the other terminal of the shunt.
andyIn your eg the tap is filling the glass and the straw emptying it
If the tap was also connected to the straw and the straw
Yeah, but stevec said it much more eloquentlythats what I said
andy
