- Nov 6, 2008
- 3,995
- 41,113
- Devon Aztec XL
- 14 years with an RV
Hi Craig.I have bought a 1500/3000w inverter, but I need longer cables from the battery to the inverter. I believe the cable is 1/0awg and I could do with approx 1m length of black and red. Where do I get some please? I need 10mm eyes at both ends too.
Thanks,
Craig
When I wanted a metre of suitable cable I just went to the local small car shop and bought a decent pair of jump leads.I have bought a 1500/3000w inverter, but I need longer cables from the battery to the inverter. I believe the cable is 1/0awg and I could do with approx 1m length of black and red. Where do I get some please? I need 10mm eyes at both ends too.
Thanks,
Craig
The installation instructions of a decent inverter will give you a small table of length vs thickness for cables to use, if you don't have the instructions see if you can download some for a good inverter of the same power you are using and follow them.but I need longer cables from the battery to the inverter. I believe the cable is 1/0awg
1 AWG is 42mm2, 0 AWG is 53mm2. Where did you get those figures? It sounds a bit OTT, I'm sure you could get away with 35mm2 for only a metre.I believe the cable is 1/0awg and I could do with approx 1m length of black and red.
They'll point you to their staff.If you do go to Halfrauds ask for
Some Fick Stuff
ass covering exercise in case you have the batteries at the front and the inverter at the back of the bus..Our 2kw Victron inverter specifies 70mm cable
How long is the van ?ass covering exercise in case you have the batteries at the front and the inverter at the back of the bus..
They don't know, that's my point, they want you to fit a cable that will be safe in all use cases so they over spec the cable size to be sure.How long is the van ?
That’s good enough for meThey don't know, that's my point, they want you to fit a cable that will be safe in all use cases .
Bigger is better as they say... until you are the one having to fit the stuffThat’s good enough for me
I did fit itBigger is better as they say... until you are the one having to fit the stuff
You can look up AWG cable sizing charts for amp rating at 75°C and size 1 will be good for 250 amps up to 100ft. (at around 60% duty cycle)
Appreciated but I don't think we have any motorhomes here 100ft longTrue, however you need to consider voltage drop, too - 100' of 1 AWG passing 250A will drop quite a few volts!
This page is quite handy
