Ivory55
On our panel in the auto trail it shows volts in the batteries and amp hours. The volts can show 12.4 v yet the amp hours remaining 100% is this normal ? Cheers
Please explain how this answers the original questioners enquiry. It's gone right over my head. No surprise as I'm quite thick.My BM1 monitor shows battery percentage remaining, hours it will take to charge with current input of power, voltage and charge/discharge rate. At the moment it is showing 90% remaining at 12.8v with no solar or charge. I have 4 x 95a wet batteries which probably doesn't help, I only really take notice of the voltage and charge/discharge rate.
I too have an Autotrail. I'm fairly certain you are ok. Be careful of members who with the best intent accidently mislead you. This forum is full of experts who disagree with each other.On our panel in the auto trail it shows volts in the batteries and amp hours. The volts can show 12.4 v yet the amp hours remaining 100% is this normal ? Cheers
In summary, he has a battery at 90% charge with a voltage of 12.8 volts. That's more like what most people would expect if the battery is fully charged, or very nearly so.Please explain how this answers the original questioners enquiry.
I think 12.4V for a fully charged battery is suspiciously low. Is it the kind of reading you expect on an Autotrail display panel?I too have an Autotrail. I'm fairly certain you are ok. Be careful of members who with the best intent accidently mislead you. This forum is full of experts who disagree with each other.
I was Right! I'm totally out of my depth. Where did the OP state his battery was at 12.8 V and how does this equate to 90 % charge. If you put a load on a fully charged battery and measure it', you will not get a true reading, this is common knowledge. The battery needs to be disconnected and allowed to rest before ascertaining its true state. Thete are plenty of threads on here that agree with this.In summary, he has a battery at 90% charge with a voltage of 12.8 volts. That's more like what most people would expect if the battery is fully charged, or very nearly so.
The OP has a battery at 100% with a voltage of 12.4V:Where did the OP state his battery was at 12.8 V and how does this equate to 90 % charge.
@SMB says his battery is at 90% with a voltage of 12.8V:The volts can show 12.4 v yet the amp hours remaining 100%
I said that 12.4V was unexpectedly low for a 100% charged battery. There are a number of possible causes, one of which, as you say, is that maybe there is a load on the battery pulling down the voltage.At the moment it is showing 90% remaining at 12.8v with no solar or charge.
Like me perhaps!The OP has a battery at 100% with a voltage of 12.4V:
I have no experience of Autotrail, so it's likely that others with more experience will have better ideas.
It doesn't answer anything, I was trying to illustrate how inaccurate some battery monitors are. Thats why I said I only take notice of the voltage and charge/discharge rate, there's too many factors to the readings to believe the accuracy of the monitor. I also have little idea of electrics amongst other thingsPlease explain how this answers the original questioners enquiry. It's gone right over my head. No surprise as I'm quite thick.
Thank you for your input on this thread. I'm of the view a battery monitor (with a shunt) is the only way of measuring a battery state in real time with confidence. If there is another device that will do this and can be permanently connected to the batteries, I would be interested in knowing about it.It doesn't answer anything, I was trying to illustrate how inaccurate some battery monitors are. Thats why I said I only take notice of the voltage and charge/discharge rate, there's too many factors to the readings to believe the accuracy of the monitor. I also have little idea of electrics amongst other things![]()
Some battery monitors need to be set up correctly. For example, if it was set up for one battery, and he added a second battery without changing the settings, it could be reading 100% even though they were only half charged,Thank you for your input on this thread. I'm of the view a battery monitor (with a shunt) is the only way of measuring a battery state in real time with confidence. If there is another device that will do this and can be permanently connected to the batteries, I would be interested in knowing about it.
I find an inverter and van voltmeter quite good for measuring battery state of charge, turn it on with the coffee machine on and if the volts goes under 12.6 the batteries were not fullThank you for your input on this thread. I'm of the view a battery monitor (with a shunt) is the only way of measuring a battery state in real time with confidence. If there is another device that will do this and can be permanently connected to the batteries, I would be interested in knowing about it.
The monitor was set for four batteries and when i bought new batteries I reset the monitor as the available amps was slightly less. I just think that the monitor readings can be misleading, having read some reviews of the BM-1 online others have said the same. Its still handy for indicating how many amps individual items useSome battery monitors need to be set up correctly. For example, if it was set up for one battery, and he added a second battery without changing the settings, it could be reading 100% even though they were only half charged,
The battery current (amps) passes through the big terminals on the shunt. The shunt is a very small but very accurate resistance. There is a tiny voltage across it when a current flows.I contacted the manufacturer a few weeks ago as when the backlight of the unit is illuminated the charge rate rises dramatically until the backlight goes off. They thought it was a problem with the shunts and recommended cleaning them which I did.
