Batteries, what do i do (1 Viewer)
AlHumphries
15
4
Kettering
Pilote Explorateur
2014, Caravans for 25 years
So, i'm guessing there is probably a fair bit of talk about batteries in here. I'm not great at maintenance, very little time for such stuff. So, brand new MH Easter last year, haven't done anything except, drive, park, plug into mains or gennie but also a fair bit of wild camping with no gennie. What do i need to do to look after the batteries? Went to the MH this weekend actually and the main battery is flat as a pancake, ordered heavy duty jump leads so will jump it and bring it home for a few days this week to plug it into the mains.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Batteries must be kept fully charged. Never leave in a prolonged discharged state or you might as well get the wallet out.
If they are sealed maintenance free then the above is all.
If open wet lead acid then you need to check electrolite levels.
treetops1
1,599
1,759
yorkshire/ lincolnshire.
Sold last van-
a long time,since 1996
You may have left something on Even your alarm will take juice out of your battery .lol
Dec 12, 2010
5,415
21,594
Cumbria
Better off taking the battery home with you and bench charging it than fannying about with jump leads, few posts on here about jump starting upsetting the EMU :(
Bartyfixedit
330
566
Maidstone Kent
Self Build Ducato L4H3
Since 1987
If a battery is flat then it has suffered internal chemical changes.
If you remove it from the vehicle and trickle charge it with a decent, correctly sized, charger you may recover it to useable, but probably never as good as new.
If you jump start the vehicle and let the alternator do it's thing you will almost definitely destroy the battery. The chemical changes cause the plates in the battery to get a coating on them that increases surface resistance and causes the plates to buckle if charged too fast.
AlHumphries
AlHumphries
15
4
Kettering
Pilote Explorateur
so what do you do when you park the MH up for the winter?, disconnect the battery?, what about the alarm and trakker?
D
Deleted member 29692
We use ours all through the winter and the solar has kept everything charged even when it's been parked up for a while.
53,485
150,252
I take it by main battery you are referring to the engine battery. On a modern vehicle they should not be left for more than 2 weeks at a push 3 weeks without charging. The engine electronics in standby , the radio, alarm all draw a small amount of current. A low current draw say 150 ma will take 25 A/H out of the battery in 7 days add to that the natural discharge of the battery you can see why they go flat fairly quickly. As you have completely flattened your battery it may recover to some extent but the chances as it will have considerably reduced it's life and I would replace it.
Hymer state in their manuals do not leave the batteries without charging for more than 10 days.
Like others have said a solar panel is probably the best option, fit and forget (never plug my van into the mains). If you install a solar set up, make sure it charges both leisure & engine batteries. An 80 watt panel will do the job and will give enough power for summer off grid camping.
movan
21,492
120,753
Moving around
Burstner
since07
So can you all just clarify please...... I havn't done anything with my batteries over winter... I leave my van without using and just hope the solar panel keeps everything ticking over... Is this ok to do? Please don't give me a complicated technical answer as I won't understand it ...Many thanks. :)
D
That works for me as well. Never had a problem. (y)
Jul 29, 2011
2,697
22,242
Urmston, Manchester
Former owner.
June 2012
My engine battery used to let me down when stood for a couple of weeks, had an 80 watt solar panel fitted which covers leisure and engine battery.
Have left it for nearly 4 weeks and it starts first time, very rarely bother with EHU when in the drive.
GJH
29,450
38,827
None, now sold
2006 to 2022
We are almost the same with an 80W panel. I do use EHU from time to time in winter, though, because buildings get in the way and mean that it can't always cope with keeping the starter battery charged as well as the leisure battery.
D
We have 200W of solar and a battery master. It's not let us down let but I'm going to get it from the storage place on Friday morning so I'll own up if it proves me wrong then :D(y)
Reactions: GJH
funkyfunky
55
43
Lassere-De-Prouille, Aude, France
c class Mercedes 310d FFB
Maintenance, maintenance, maintenance, Trickle charger or solar panel with auto regulator is the answer and must be used when not driven .
Best wishes My Friend and enjoy.
GeriatricWanderer
1,194
4,199
Ouagadougou, Burkina Faso, just cos I can!
Pop-Top Campervan
45years
If you do have to leave the van unused for some time but still have reasonable access to it then keep an eye on the charge from time to time - very effective and cheap meters on Ebay etc. If the charge is OK then you can sleep at night, if it's not then you can catch it early and fix it.
23,836
72,539
Most vans in standard trim do not charge the vehicle battery from solar panels ( there are some with a split charge as standard but they are few )
It is also the case that a LOT of vans do not charge the vehicle battery even when on hook up
So the first thing to do is get a multimeter ( plenty of then around for less than a tenner if you have not got one ) and check the battery voltage off hook up
Then plug in the EHU and check the battery again.
If it has risen then you know it charges when on hook up.. so that is that side sorted.. If the voltage remains the same then see Note 1 below
Next, solar panels.. it is even rarer for a standard solar panel set up to put anything in to the vehicle battery.. See note below :)
Note below .... ( :) )
I would suggest you get along to EddieVanBits and get your self a nice B to B splitter..
Extremely easy to fit and can be done with very basic skills and basic tools
What a B 2 B widget does.
There are usually three wires coming from the wee box.
One goes to earth, another to the live side of the vehicle battery and the last to the live side of the hab battery or batteries
When the hab battery reaches a charged state the B 2 B unit will bleed off any excess and put it in to the vehicle battery.
It will work no matter if you are on hook up or indeed relying on solar panels
Millibobs
101
21
Sax Alicante area Spain
Overcab
I think the same as one of the other funsters , you need to fit a solar panel to keep all batteries topped up and healthy. Mine is only a 50 w one but has done the job for the last 10 years. Mind you I live in Spain and maybe in the UK you need more than this to be sure.
TheWM
445
450
London
Rapido 9010df
Newbie, but over 10 years in a campervan
Does it (the B2B unit look like this?)
I'm trying to work out whether my solar is keeping the starter battery topped up.
23,836
72,539
If what I am seeing is a module with a massive bunch of wires connected is what you refer to.. It is certainly not like any B 2 B unit I have ever seen !
But I have not seen 'em all :)
More usually there are just three or four wires going to it.
Is there anything printed on the module ?
Abacist
3,752
10,839
Devon
N & B Arto 88F Tag
since 2013
That just looks like a standard Fiat engine battery installation in the passenger seat footwell. If your van is standard as bought new you probably haven't got one. Do you have a button on your control panel to select charging the engine battery instead of the habitation batteries? You have not given the make and model of your van which would no doubt help someone on here advise you.
I have just installed a Vanbitz Battery Master in my AutoTrail and it's fantastic. No more having to remember to go out and press the button to change which battery is getting the charge!
TheWM
445
450
London
Rapido 9010df
Sorry it is a Rapido A class (9010df)
No switch that you refer to on the control panel but it does have a few 'extras'. I'll take a pic of what I believe to be some kind of battery master later.
TheWM
445
450
London
Rapido 9010df
Didn't get to the battery as need to shoot out but did take a pic of this (sorry it is installed upside does). It says CAC computer automatic charger. I also have another thing next to it which I assume shows the solar power in operation.
Abacist
3,752
10,839
Devon
N & B Arto 88F Tag
since 2013
Hopefully an experienced Rapido user will be along in a minute to explain what you get as standard on a new Rapido van and how it all works. I fully admit to not having a clue what they do in their vans.
TheWM
445
450
London
Rapido 9010df
@Jaws got to the module and it reads jaeger trailer module. I'm pretty sure I don't have anything topping up the starter battery as it has now dipped to 11.4v and is flashing on the panel. Pic of module below.
TheWM
445
450
London
Rapido 9010df
Here is a pic of what was hidden beneath the cover of the battery. What is everything doing there?
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
As long as the solar charges BOTH hab and engine batteries (Battery Master maybe) they will be fine some vans do NOT charge both batteries.
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
I've made a removable split relay circuit that will top up the engine battery from the (solar powered) leisure battery when in storage, but over winter my 85W panel (mounted flat on the roof) isn't enough to keep the charge up, so I have to drive it around every four weeks or so, or bring it home and put it on the EHU for a day or two.
That said, the leisure battery has gone to a low voltage on at least three occasions over winter but still holds a decent charge for everyday use. Likewise the cab battery has got to the point where it won't start the engine on a few occasions but it's recovered again. I monitor the voltages constantly as a precaution and there's been no substantial change in the last three years, despite occasional low spells.
Always worth investing in a multimeter and a couple of 12v socket voltmeters if battery state is something that you want to keep tabs on.
43,332
49,527
View attachment 62938 @Jaws got to the module and it reads jaeger trailer module. I'm pretty sure I don't have anything topping up the starter battery as it has now dipped to 11.4v and is flashing on the panel. Pic of module below.
That is a canbus bypass relay module for trailer lighting.
Stops the vehicle canbus system from realising there are extra lights and throwing up lighting faults.
