Bathroom problems (2 Viewers)
May 17, 2016
3,633
7,877
Aberdeenshire
B524
2nd base
Right I've got 2 problems with the bathroom area on my 524. 1 is an ongoing problem that I thought had gone away and the second is a problem that just happened today.
1st is a leak somewhere in the drainage system - I thought it was coming straight from the 2 drains that are used for shower water only but last night I was using the sink only and the small amount of water that I used seeps through from somewhere and usually comes out where the wooden panel of the sofa unit meets the floor, see arrow on pic here, although it depends which way the van is tilted.
So how on earth do I get in to check the drainage system?
2nd problem is more straight forward. The spring loaded catch that keeps the sink panel in place has snapped. See here:
Could this be repaired (plastic welded?) or would that not leave it strong enough seeing as it is used every day? If it can't be repaired, where would I get a whole new panel?
monzer
May 17, 2016
3,633
7,877
Aberdeenshire
B524
2nd base
Does the seating not come out.
ie cushions lift off to reveal an access panel
Had them off and there is a little access panel but I can't get it off as I haven't got right screwdriver in the van. It's a tiny little hatch though so I don't think I'm going to see much even when I do get it off.
Jan 8, 2013
8,496
11,538
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
I had a leak in the drain pipe under the sink that couldn't be reached. I cut the drain pipe where I could reach it and dragged the whole length out. I repaired the joint that hadn't been glued and pushed it back under. Bought a new joint for where I'd cut it. Good luck. Also check the shower tap is not leaking at the back when you turn it on.
monzer
May 17, 2016
3,633
7,877
Aberdeenshire
B524
2nd base
Doesn't seem to be any leaks in the tap/shower head itself. I'd need to take of the blue plastic panel that hides the rest of it to make sure and don't want to be doing that unless I really have to
17,661
43,541
the waste pipes are often only push fit, so a build up of soap scum, detritis and scale slows the flow enough to promote a leak. A thorough clean and brush through with a long bottle brush and hot soapy water will help keep it clear. but long term it is best replaced with smooth bore pipe, ideally larger than that already fitted
the spring latch, you wont find a replacement, rivet a strip of aluminium over the broken part and it will work. paint the aluminium white so it blends in
seakay22
160
525
Malibu GT600
Since 2002
Cover and stuff everywhere with toilet paper, turn on taps/shower, wait a few minutes then inspect. Water has almost magical powers of finding its way to places it shouldn't.
Silver-Fox
9,290
29,325
Cheltenham Spa
Rapido
im a not so newbie
Is the seat base screwed in place.
Ours is, different van, then you access below.
Feb 22, 2011
9,936
20,523
Newcastle under Lyme
Hymer B544 A Class
Can you look in the floor hatch by bathroom and see any waste pipes and location of waste tank ?
On mine there is a wardrobe / boiler cupboard between bathroom and sofa and a shoe shelf can be lifted to give access to waste pipe.
My basin retainer snapped exactly the same as yours has. I removed the panel and glued a piece of strong plastic with sikaflex to act as a hinge.
This lasted a while but came adrift eventually so I re-did this time adding four (2 on each side) Allen key stainless steel bolts painted to match. Actually sprayed the whole thing.
It's worked fine for about three years now and doesn't look too bad.
I think the plastic I used was a uPVC glazing wedge.
monzer
May 17, 2016
3,633
7,877
Aberdeenshire
B524
2nd base
I've lifted the hatch outside the bathroom door and found a bit of water. That's what led to me thinking it was the shower drains but it's obviously escaping a bit further back.
The sofa base is hinged and you can swing it up out the way. Plenty of space there but can't open the other access hatch to have a look until I'm home for tools. I'll be home tomorrow.
Looks like I'll just have to bodge the spring latch. At least the spring actually holds it in place so it is workable for now.
Puddleduck
12,396
44,125
Scottish Borders
Without at present
On and off for many years.
Are you sure it is the waste that is leaking? Ours was on the supply side but an easy fix done under warranty.
Nanniemate
6,254
43,905
Wales
IH
I have a similar problem use food colouring red sink green shower put down each drain separately white look roll or similar and which ever bit is leaking will be that colour. I found my leak that way. But getting in to fix it is a whole new ball game. Good luck
monzer
May 17, 2016
3,633
7,877
Aberdeenshire
B524
2nd base
A bit late back to this but I have had more time to investigate this problem as I am fulltiming and my back is fixed allowing me to get in to the nooks and crannies!
You seem to have got it spot on TheBig1
I traced the leak to only the sink drainage pipe which comes down under the floor just in the toilet cassette locker and to the left. Black plastic pipe push-fitted in to an 90 degree elbow. As you can see in the video it has been leaking for sometime and has left me with a lovely gunk of soap scum and scale.
Now I reckon I can unscrew the corrugated hose in the shower room and it should allow me to being the black pipe up and see what's going on.
If it is just push-fit can I clean it and hopefully push it back in to place? Or will I need some kind of sealant?
Excuse the mess!
ok video wont upload so just a screenshot...
Emmit
8,073
17,850
Pilote Explorateur
Jan.2014
If you can disconnect that pipe and be able to take it to a plumbers merchant, they should be able to tell you whether the plastic used is suitable for accepting the solvent glue to stick the pipes together meaning that it won't leak again.
I would rather have a 'natural' bend in plastic pipes rather than a fitted elbow.
monzer
May 17, 2016
3,633
7,877
Aberdeenshire
B524
2nd base
Just tried but I can't get it disconnected. I think I'll need to way until someone at work on Monday can stop it turning on the outside when I try and loosen it on the inside.
17,661
43,541
You have my sympathy as what goes down as soap and dirty water ends up as a gooey stinky mess. Pretty much every one I have taken apart I ended up splashed with the vile stuff. When re-instating I try and fit as big a smooth bore pipe as I can get in, with a reducer to fit the sink and tank. Aquarium/fish tank places are much cheaper and have the bits in stock usually
Not a job I enjoy, you have my sympathy
