Right I've got 2 problems with the bathroom area on my 524. 1 is an ongoing problem that I thought had gone away and the second is a problem that just happened today.
1st is a leak somewhere in the drainage system - I thought it was coming straight from the 2 drains that are used for shower water only but last night I was using the sink only and the small amount of water that I used seeps through from somewhere and usually comes out where the wooden panel of the sofa unit meets the floor, see arrow on pic here, although it depends which way the van is tilted.
So how on earth do I get in to check the drainage system?
2nd problem is more straight forward. The spring loaded catch that keeps the sink panel in place has snapped. See here:
Could this be repaired (plastic welded?) or would that not leave it strong enough seeing as it is used every day? If it can't be repaired, where would I get a whole new panel?
