Autotrail Frontier spare wheel cover marking rear gel coat (1 Viewer)
Oct 10, 2009
887
1,970
Bishop's Stortford
Autotrail Delaware
Since 2011
I took off my spare wheel cover today to clean underneath and check the wheel and tyre and noticed that the bottom of the cover was wearing a groove on the gel coat on both sides. I read something about this on the forum recently but cannot find it. I need to make a gap between the cover and the motorhome at this point or I can imagine it will eventually make two holes!
Has anyone else had the same problem, or a similar one, and found a solution?
Aug 18, 2014
23,879
134,662
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
i'd just use armaflex sticky insulation tape on the bodywork where it touches.
this stuff or similar
<Broken link removed>
Aug 17, 2011
407
1,020
Wrexham
Autotrail Arapaho
since 2005
I've used this.
Obviously on eBay. Don't know how to put a link, I'm sure you can find it from the photo.
Jul 29, 2013
9,076
18,675
Salisbury
Hymer B678DL A class
I had that problem on our Tracker I fitted some self adhesive rubber draughty excluder around it and that worked wellšŸ˜ŠšŸ‘
RM_Marine
684
1,173
Poole, UK
Autotrail Apache 700
Since 2021
RM_Marine
684
1,173
Poole, UK
Since 2021
It was me that found this out but I'm also going to buy the door boot edging
Darloman
37
58
I too had this problem on my previous van (Mohawk). The way it was rectified was to replace the factory fitted wheel cover seal with a softer compound extruded rubber seal. That cured it.
RM_Marine
684
1,173
Poole, UK
Since 2021
So wheel cover fixed and completed and I have to admit that the edging from ebay was and is very good
Also added some L shaped brackets to keep it away from the van body
RM_Marine
684
1,173
Poole, UK
Since 2021
Nope only fitting to the top half and the bottom half isn't which then becomes warn and sharp and cuts into the body of the van and makes holes
RM_Marine
684
1,173
Poole, UK
Since 2021
This is also the same on the newer model of autotrail where the black edging is on the top of the wheel cover
