Very true, but nothing to do with why these peel. It’s as Stephen Franklin said above. The lacquer has no key and the edges are too sharp.Galvanic corrosion, also known as bimetallic corrosion, is an electrochemical process whereby one metal corrodes in preference to another metal that it is in contact with through an electrolyte.
Galvanic corrosion occurs when two dissimilar metals are immersed in a conductive solution and are electrically connected. One metal (the cathode) is protected, whilst the other (the anode) is corroded. The rate of attack on the anode is accelerated, compared to the rate when the metal is uncoupled.
For example, if aluminium and carbon steel are connected and immersed in seawater, the aluminium will corrode more quickly, whilst the steel will receive protection
Salt water from the road or if you live near the sea will cause it to happen again unless the wheels are coated
The wheels are coated, it’s the lacquer coating coming off.
You would think that is a distinct possibility but on our new replacements it started around the small hole edges and large hole edges, not inside the the large holes where the bolts are, though it progressed to there.I think it's the steel wheel nuts reacting with the wheel........
Thanks, everyone. And my guess is this post hit the nail on the head. We insisted on “new” wheels when we bought the van secondhand due to corrosion. Who knows if the “replacements under warranty” were refurbished wheels or otherwise :-(Might as well have them refurbished...... The 'replacement under warranty' ones will already be refurbished previously exchanged wheels.
Wait until they start deflating over six months then 5 - 4 - 3 - 2 - months etc. You've all that to look forward to yetThanks, everyone. And my guess is this post hit the nail on the head. We insisted on “new” wheels when we bought the van secondhand due to corrosion. Who knows if the “replacements under warranty” were refurbished wheels or otherwise :-(
i should probably have acted sooner as we have corrosion spots at the rim on all four wheels.
Yup, my merc had flat tyres until I got the wheels refurbished.Wait until they start deflating over six months then 5 - 4 - 3 - 2 - months etc. You've all that to look forward to yet
I think if I had them I would wax them every month to stop the external corrosion..Actually I'd sell them while they still look good and buy a much better type of alloy... Steel
How did you get anywhere then .Yup, my merc had flat tyres until I got the wheels refurbished.
When Hymer replaced my corroded wheels the replacement wheels were completely different, of the type used on newer models.Might as well have them refurbished...... The 'replacement under warranty' ones will already be refurbished previously exchanged wheels.
Sea water apart, I think a lot of those corroding alloy wheels are caused by regular visit to hand car washes. In order to work fast, these people use a very acidic degreaser to spray on the wheels before washing the vehicle. I would only use a hand car wash if they used Autoglym products and I only know one 20 miles away from where I am.
Four please!I've got an idea for a new productimagine if you will a high resolution wheel sized circular photo of a diamond cut wheel in high quality perspex stuck on a wheel trim!
You could even slide the photo out and a new one in, you could change to rostyles, normal alloy or a rusty steel anti theft one![]()
If the description you gave was steel against aluminium I think it would be correct. Whilst not dissimilar another process is it work here the laquer Is supposed to protect the metal so the question is how are why is the coating failing in order for corrosion to occur.Galvanic corrosion, also known as bimetallic corrosion, is an electrochemical process whereby one metal corrodes in preference to another metal that it is in contact with through an electrolyte.
I am guessing here but I would suspect that the wheel nuts bite through the lacquer when tightened and the problems start from there. If so the the lacquering process appears to put pretty appearance above functionality.If the description you gave was steel against aluminium I think it would be correct. Whilst not dissimilar another process is it work here the laquer Is supposed to protect the metal so the question is how are why is the coating failing in order for corrosion to occur.
