• Well done, you found us. THIS IS THE NEW SERVER
Alloy Wheel and Steel Wheels Do They Use The Same Bolts? (1 Viewer)
zac
2,625
1,884
Basingstoke
Rapido A CLass 10000
since 2013
After seeing a post on here where someone was selling a steel wheel with the bolts it got me thinking do steel wheels and alloy wheels use the same bolts? As if not i need to get some bolts to fit the steel spare?
Sorry if a stupid question, i just assumed the bolts already on the vehicle holding the alloy wheels on would do the same in the event of a mishap and the steel wheel needed to be used.
Thanks in advance.
19,523
31,106
If the steel came as a spare I would say it should have the correct bolts with it, my guess would be different bolts though.
  • Informative
Reactions: zac
Z
zac
2,625
1,884
Basingstoke
since 2013
Never came with a spare, i purchased this myself then added the tyre and high pressure valve to ensure i am covered if i get a puncture etc. Next question if i cannot use the same bolts how do you know which ones to purchase?
11,860
14,117
I assumed they would be the same and was wrong. Luckily my mechanic pointed it out before I had to find out in anger. The steel wheel ones are a different length so you will need bolts to go with it. My spare wheel was 2nd hand on ebay so definitely no bolts supplied with it.
  • Informative
Reactions: zac
19,523
31,106
I would think if its a Fiat wheel Fiat will sell bolts for it.
Z
zac
2,625
1,884
Basingstoke
since 2013
Where did you get your bolts? as now need to source a set.
Silver-Fox
9,290
29,345
Cheltenham Spa
Rapido
im a not so newbie
Steel wheels and Alloys use different bolts.
Length will be different and sometimes the chamfer is.
Ebay is the source of all things wheel bolt related ?
19,523
31,106
If it's a Fiat copy the standard studs for steels may be correct still, you need to check the face that the stud sits on, is it flat or angle and then compare.
11,860
14,117
Sorry cant help with that, I just got my mechanic to supply suitable ones when he pointed it out when he fitted the tyre to the steel wheel. Mine is Mercedes not Fiat BTW.
  • Thanks
Reactions: zac
Z
zac
2,625
1,884
Basingstoke
since 2013
This is the steel replacement
Two on Tour
10,443
52,142
Elddis Autoquest 175
The alloy wheels I bought recently for our van were designed to use the original vehicle wheel bolts although I got them with spanky bling chrome bolts, so I think it really depends on the alloy wheel manufacturer.
MikeD
3,936
3,697
London
IH PVC
Bolts usually come with either a 60 degree taper or a dome. I don't know what is the fitment for a Mercedes but sometimes the length might be different.
I would talk to the wheel supplier. The maker will be marked on the wheel somewhere, usually on the inside edge of the spokes.
Z
zac
2,625
1,884
Basingstoke
since 2013
This is the original alloy wheel
Z
zac
2,625
1,884
Basingstoke
since 2013
Need to source something quickly as off in 12 days.....
17,666
43,561
both alloys and steels on the fiat ducato have a domed shoulder. the bolts for the steels are about 8mm shorter.
  • Informative
Reactions: zac
Z
zac
2,625
1,884
Basingstoke
since 2013
Just read the original listing on ebay and is states the original bolts can be used but it doesnt state if you had alloys on if you can still use the original bolts see HERE
Z
zac
2,625
1,884
Basingstoke
since 2013
JockandRita
11,520
150,999
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Its not alloy as i already have 6 alloys, the spare is a steel though. Unfortunately i have no idea what i am looking at so i think i will call the company i got the wheel from on Monday and see what they say. I will go out in a bit and see if the wheel will take the original bolts.
My post has been amended, just as you posted, ie, also lists for steel wheels. (y)
Jock. :)
  • Thanks
Reactions: zac
17,666
43,561
the cheapest source of standard steel wheel bolts is a commercial vehicle scrap yard. usually £1 each
Jul 1, 2010
3,214
35,214
SW Northumberland
Hymer B 588 DL
Since September 2010
My Hymer manual states they are different (Fiat) and my dealer had to supply a set for the steel spare, this was discussed on another group and it was suggested that alloy studs are longer therefore could project further through the hub and cause damage.
  • Informative
Reactions: zac
Jan 28, 2008
10,138
18,421
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
if you do face book theres a guy on there going by the name of zacsrings who is a guru with all things wheel related you could try a google search of his name he pops up on a lot of selfbuild sites as well as onr make groups supplying center rings and bolts for wheels swops seems to know what his talking about
  • Informative
Reactions: zac
Oct 20, 2010
2,252
37,625
Burry Port South Wales
Since 2003
A French tyre fitted a steel spare on our fiat based van after a puncture on one of the alloys. He used the same bolts but was carefully checking the clearance by rotating the wheel while they were tightened.
Cheers
Ed
  • Informative
Reactions: zac
54,095
152,694
On a Fiat the shoulder angle is the same for alloy & steel. Bolts for alloys are 2mm longer so fine for a steel spare.
Its not a genuine fiat wheel but it does fit.
Have you checked the load rating, most aftermarket wheels have a lower load rating than genuine Fiat ones so not suitable for a Motorhome.
Z
zac
2,625
1,884
Basingstoke
since 2013
Yes i checked the load rating when i brought it and i think it was 1250kg which i have 6 wheels and the max weight is 5t so under per axle with the spare.
I have taken so pics of one of the bolts from the alloy that i have just taken off.
Z
zac
2,625
1,884
Basingstoke
since 2013
So my existing bolts should be ok?
bobandjanie
8,177
15,852
Javea, Spain
Pilote V600g
We didn't get extra bolts for ours, so I think they will be the same, but I did get one of these, and having trucks with alloy wheels and knowing how they stick I would say it's a puller to get the wheels off. :Eeek: Bob.
Lenny HB ? Or maybe a tool to line the bolts up putting the wheel back On.?
Silver-Fox
9,290
29,345
Cheltenham Spa
Rapido
im a not so newbie
Lenny HB ?
Do people not put a smear of copper grease on the mating surfaces of alloys and steels now a days ?
