Talking 70 years ago but seems like yesterday.This is true, my father had an Austin seven, and when we got to anything above flat road we had to get out and push it.
Probably unbelievable to most folks now.
Good times
Good times
I live near Sutton bank, stick it in manual second gear on approach and hope the prat’s behind keep back. It’s a 25% gradient and I get a lot of scarey wheel spin from the front tyres in the wet so take the diversion if it’s rainy. Not tried Chimney Bank yet as its more than 30%yep been up Sutton bank with a 4x2 113M 360bhp at 38ton , made me sweat a bit but I stopped at the wee layby half way up and selected 2nd and just kept her singing .
Didn't attempt to change up until it levelled out near the top
I have had to get out and push hubby’s minivan up Tog Hill.This is true, my father had an Austin seven, and when we got to anything above flat road we had to get out and push it.
I had the luxury of a 180 bhp Gardner in a Mk 2 Atki Borderer with a six speed David Brown box.And only a 150 brake horse Gardener under the bonnet.BUSBY
No need for high revs, go at a steady speed. Be kind to your machineThanks Busby - the van is 1997 so may not come under the description of modern. Can the van take high revs without any problem when getting it up a steep hill?
Get in the low gear early, even if it seems silly at first and high revs, as changing down on a steep gradient is daunting at the best of times and our handbrakes just aren't up to the job.
Hi jopparocks its all about predicting the correct lower gear early enough on steep hills, especially when you come across a few blind sharp bends that knock off your speed very quickly. Luckily we have synchromesh on 1st gears these days, it would have been a lot harder with much gear crunching in the old day.
I just google earthed the road over Cairn o Mount, and yes it is steep with many potholes due to the winter snow, which sometimes are impossible to miss.
I have found you the best tool to have another go at this trip, with the wife safely strapped in I am sure she would love the experience, I know I would, so enjoy.
LES
Sorry I don't agree with that. What if the incline was a mile or so, you wouldn't want to do the whole thing in first gear would you? Diesels are made to rev high when needed. Just change up in good time and keep the revs high that way you should be able to keep it moving fine.Seems then that the advice is to get the gear right before getting on the hill and then stick with it and never try changing down.
I think you may have to explain a crash box to some of the funstersGood fun going up those sort of gradients with 32 tons and a crash box
Manys the vehicle that had to go up Porlock Hill, or the old Telegraph Hill by Exeter before it was levelled out, in reverse. And that was only in the 60s.Talking 70 years ago but seems like yesterday.
Every hill is different, lots of factors to take into consideration regarding changing gears on a steep hill.Sorry I don't agree with that. What if the incline was a mile or so, you wouldn't want to do the whole thing in first gear would you? Diesels are made to rev high when needed. Just change up in good time and keep the revs high that way you should be able to keep it moving fine.
I take the view that those behind me on a narrowish road will have to bear with me even if they are frustrated. Just because the road say has a 50mph speed limit it does not mean that you have to go at 50 you go at a speed up to that that you as the driver judge to be safe and within your own driving experience and limits. We have just been in Somerset using very narrow roads all twists and turns on the look out for those huge four wheel drive tractors taking up more than half the width of the road. Knackered my passenger side mirror avoiding one.Nowadays everyone thinks that everyone should go at the speed limit, but the roads were built for all sorts of traffic even horses and walkers and God forgive even people on bikes, if you have to go up a hill in first gear that's your perogative.
Going down Porlock is also interesting requiring low gear and judicious use of the brakes.Manys the vehicle that had to go up Porlock Hill, or the old Telegraph Hill by Exeter before it was levelled out, in reverse. And that was only in the 60s.
A doddle in my 5t 3L V6 Merc Frankia, lost count of the number of times we have been that way.Been over the pyrenees (sp? ) Spain to France via Andorra in my 3850kg 2.8 diesel Kontiki no problem.... Even the switchbacks above the tunnel presented no trouble. Low gear and just plod up.
We just had our Motorhome when my wife drove up that. She changed down to 1st gear so fast I barely saw her move. She absolutely went code brown but it was fine.Manys the vehicle that had to go up Porlock Hill, or the old Telegraph Hill by Exeter before it was levelled out, in reverse. And that was only in the 60s.
Hi, what chassis, year and gearbox do you have ?Hi Everyone. Just came back from a trip from the east of Scotland and one of the routes took us over Cairn O' Mount which has a couple of approach roads quite steep - up to I think 16% but definitely 14%. The Hymer has taken long gradients in its stride before this (it went up Glenshee pass without any problem albeit in third gear and that is 17%) I was fairly confident going up this particular hill. It wasn't long But - On the hill there wasn't much of a chance to get a run up to it and so I started going up in third then second then had to go into first and each time I had to change very fast as it slowed down very quickly and in the end it ran out of power and I had to do a hill start. When stopped the hand brake started to slip which was quite worrying but managed to get it into another notch but of course it was hard to get off that notch when I had the revs up and started releasing clutch. Managed it in the end and no one behind so all worked out.
Is there any advice any of you more experienced big van drivers or truck drivers with manual gears have that would give me more confidence next time? Wife is now worried about going up steep hills and has ruled out North Spain or the Pyrenees both areas that I want to go to when I retire in a couple of years.
The van is a 4.6 tonne Hymer with 2.8 diesel engine. We had a half tank of water but apart from that nothing particularly heavy.
Cheers Martin
Thanks Steve - you guys are giving very useful advice to meSorry I don't agree with that. What if the incline was a mile or so, you wouldn't want to do the whole thing in first gear would you? Diesels are made to rev high when needed. Just change up in good time and keep the revs high that way you should be able to keep it moving fine.
Have heard the term many times but don't know what it is.Double declutch, if you know how.
Its a 5 speed manual gearbox with the gear stick coming through the floor on a mercedes 412 D chassis with a 2.9 turbo diesel. 1997, Its only done just over 70,000 miles. 4.6 tonne.Hi, what chassis, year and gearbox do you have ?
The 4.6t sprinter was available with final drive options , from memory, three.Its a 5 speed manual gearbox with the gear stick coming through the floor on a mercedes 412 D chassis with a 2.9 turbo diesel. 1997, Its only done just over 70,000 miles. 4.6 tonne.
I still do by habit but I believe it's not good for modern gearbox's.BUSBY..Double declutch, if you know how.
Most crossings of The Pyrenees are transversed by 44 tonne artic's so should be no problem for Motorhomes.BUSBY.A doddle in my 5t 3L V6 Merc Frankia, lost count of the number of times we have been that way.
I think I heard a lot of gearboxes now are higer ratio in reverse than first so it wouldn't work.Many moons ago (late50s) I had an ex-post office series E morris van. Went to Bognor in it but it would not go up Goodwood hill in first. Had to reverse all the way up.ahh the heady days of motoring
