Adria twin boiler drain down (1 Viewer)
Dave_E
117
77
Just looking
I'm a newbie
Trying to drain down the truma combi 4e boiler but can't see a valve to do it.Any ideas.
Riverbankannie
10,568
61,806
Bristol
IH 630 RL PVC
Mine looks like this and is situated by the boiler.
Jan 8, 2013
8,491
11,530
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Lift the yellow lever--- You should have an automatic frost valve on the boiler that will open at about 3 degrees.
D
Dave_E
117
77
Just looking
I'm a newbie
No yellow valve to be seen.I wonder if you drain it using the frost valve which.is about 2 ft. Away.
Dec 10, 2013
3,423
12,254
South Staffs
Pilote P740GJ
Do you have a frost valve, just turn the lever on top 90 deg and make sure the button at the back has popped out.
Truma-Trumatic-Drain-Valve-Frostcontrol-Set-2-8-BAR-Years-0-15-32in
D
Dave_E
117
77
Just looking
I'm a newbie
Many thanks everyone.Do you suggest I leave the frost valve open until I next use it.
Nov 23, 2011
479
405
durham
Lowline
since 2006
If its to winterise the van yes.Best to leave all taps open in midway position also. Drain fresh water and grey water tanks empty and valves open.
Oct 13, 2016
1,050
897
Grays - Essex - UK
Mercedes Hymer B680
Been moho’ing for a time now
If you can’t find the dump valve try disconnecting the battery for a moment ? Then check underneath and watch for the water coming out
D
Dave_E
117
77
Just looking
I'm a newbie
All done let the winter do it's worst.Many thanks.
Jan 8, 2013
8,491
11,530
Burstner Lyseo 690G
I have the Mb Hymer B 680, the whole moho is reliant on the ebl unit, when the voltage drops to about 10 volts the heater dump valve opens and drains the boiler
Eh? That's a new one one on me.
The battery voltage? Why would you let the voltage drop to 10V - that's a knackered battery?
Oct 13, 2016
1,050
897
Grays - Essex - UK
Mercedes Hymer B680
That could OBVIOUSLY be a number of reasons, but trust me if I disconnect the leisure battery the little valve thingy opens and dumps the boiler water
denisejoe
5,625
12,055
Warden isle of sheppy
If I turn the power off to the taps water system on control panel water heater dumps
