Lift the yellow lever--- You should have an automatic frost valve on the boiler that will open at about 3 degrees.
I have the Mb Hymer B 680, the whole moho is reliant on the ebl unit, when the voltage drops to about 10 volts the heater dump valve opens and drains the boiler
Those are the old ones the modern ones are mechanical no electrical connections.That could OBVIOUSLY be a number of reasons, but trust me if I disconnect the leisure battery the little valve thingy opens and dumps the boiler water
You are probably correct ? Mine is a 2001 model, but I love itThose are the old ones the modern ones are mechanical no electrical connections.
If I turn the power off to the taps water system on control panel water heater dumpsEh? That's a new one one on me.
The battery voltage? Why would you let the voltage drop to 10V - that's a knackered battery?
