Geo
Trader - Funster
- Jul 29, 2007
- 11,757
- 14,565
- Autotrail Tracker FB
- 45 +years with breaks
What im needing is advise or information regarding replacing the safty lock/lever in the right hand end plate on the RV awning.
Linda at Stateside Tuning is on stand by and has supplied Operating instructions in a down load to me, however what would be better is the repair or instalation documents
As the awning tension and operation is 100% im thinking that in the closed position (Minimum Tension) it may be possible to just remove the end plate and replace with new cpmplete unit, or if available a repair kit for what I asume is a pawl and ratchet system inside, when replaced it would only then require a minimum amount of turns 2 to 3 at most to set the load as the awning applies full tension as its wound out.
Anyone know if im on the right track or am I in cookoo land, and its a full removal and strip down, please bear in mind im a mechanic and if I could fit brake pads by putting them in the master cylinder i would
Do any of our American cousins know the right way to do it Tom!!! where are you
Geo
Geo
