590rs Electric Hook Up Issue (1 Viewer)
HSE
WELSHPOOL
Suntor 590RS
HI
I have two issues/ questions on 240v electrical hook up
Verhicle Battery appears to loose charge when connected?
Lights do not work unless leisure battery is selected?
Any help would be much appreciated
Heather
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
HI
Heather
Hi Heather
Firstly how old is your Sundance as the earlier models didnt have a charging facility from hookup! In this case i would get your dealer to put a test on the battery to see what amps are being pulled from it and this should determine if the battery is ok or not!!
Your lights should work when either vehicle or leisure battery are selected, if they only work on the leisure side then we would start by looking at the fuses to the vehicle battery.
YOu are more than welcome to contact uur workshops on 01580 881288 / www.johnscross.co.uk.
Good luck
Glenn Harris
17,633
43,350
not certain why you think the hook up is discharging the vehicle battery, as it is not connected to the leisure side other than through the source selection switch
The lights will only work when you select the leisure battery. all that you are doing is supplying a battery charger in effect to the leisure battery but it remains the source of power to the lights, pump etc
to charge the van battery when on hook up you need to select it at the control panel. As I recall on those vans its a 3 position switch leisure battery/off/van battery
if you are still having issues after this, I would suggest that you need to talk to your supplying dealer or an auto electrician to figure out whats not working correctly
H
HSE
WELSHPOOL
Suntor 590RS
Its a 2005 Swift 590Rs - used to get 12 volt power when selected central position ie not vehicle or leisure battery. But don't now - when hooked up and vehicle battery is selected it drains within 2 days where as if not connected to 240 volt does not drain for weeks ?
I've changed all the fuses but still no success
Heather
voyager 1
92
34
Durham Tees valley
c class Swift voyager
30+yrs
May be a daft question ? how old is the vehicle battery, that might be the problem not that i am an expert but most of my vehicle batterys in the past seem to last about 4/5 yrs then they stop holding a charge because one or more cells have died.
43,331
49,482
sounds like battery charger has an internal short circuit on the output side (12v) allowing battery voltage to return to the charger and subsequently to earth
H
HSE
WELSHPOOL
Suntor 590RS
thanks all - yes 240 V connector gives us power through sockets -
I have now changed charger and still have the same issues
Short circuit seems like a possibility any ideas where i could find it pappajohn?
