2000 watt inverter (1 Viewer)
chrisgreen
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
So you've fastened 50cc a lawn mower engine to standard 70A alternator.
Got to admit, as a battery charger the theory is good. Only doubt is if the little motor can crank it at that 70A, probably will.
it does brian:thumb:all to do with the gearing
and its a new honda gxh50(i give £35 for it) mixer engine,but the thing is i dont have to run it for long as it will charge pdq:thumb:
and if the alternator goes pop i can get one from any scrappy for £20:thumb:
scotjimland
2,335
10,105
A Woosh bang
and how many amps does that push out 1 amp if lucky on a screeming 2 stroke,its not the same might be 12v but not the same.not even similar.
your correct it's not similar .. it is a lot lighter and>>>> I quote
capable of I would guess 30A, although so far only tried it on slightly discharged batteries and got 15A.
not bad for a little strimmer ... even if it is noisy
chrisgreen
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
but a slightly discharged battery is not a test,i have tried this on a battery showing 10volt and bought it up to 14.5 volt in about 20 mins,now thats a test:thumb: i have also run this connected to a fully charged battery while useing a 1000watt 230v hair drier through a 2000watt inverter now thats a test:thumb:
chrisgreen
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
just been on facts:Eeek:,may god strick me down,and live the rest of my life in burning hell:ROFLMAO::ROFLMAO:
and had looksee that unit is not in the same class as mine it would shake its self to pieces if a realy heavy load were put on it:Eeek:
i can hear a strimmer being used half a mile away, mine aint that noisy:thumb:
but i like it:thumb:
chrisgreen
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
and im taking it to the weston show as my only sorce of charging batteries,to give it a full test over four days,i would say it will only need to run for about an hour a day?????
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
To do this the "normal" way you would need a 1kW genny plus a serious 70A charger.
To use that genny with the normal 20A(ish) MH charger would indeed take three times longer.
