X250 engine earth strap and failed hot start. (1 Viewer)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I've found several threads across the web detailing the same symptom of failure to re start a hot engine.
Normal starting from cold is fine but after a journey the first attempt at restart often fails.
The popular answer is to replace the engine earth strap.
This picture borrowed from O&AL
I've not had chance to prove it yet but I did 10 consecutive cold starts and all fired as fast as you can say 1 2 3 with no hesitation. I've replaced with a shag of 70mm welding cable.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Some may ask why would being hot change things?
I believe it is to do with increased cylinder pressure and thus higher cranking load.
17,637
43,384
as you know, but others may not, the easy, belt and braces way to check if its the earth strap is to connect a good jump lead from the battery negative to the engine block. if the problem goes away with the jump lead connected, then its fair to assume the earth strap has rotted. a pretty common fault on many different vehicles, not just Fiat ducatos
jonandshell
5,476
8,299
Not got one!
It could be another reason Andy.
The resistance in the earth strap could cause all sorts of problems with the analogue inputs to the ECU and this could screw things up.
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
Set your Multimeter to the lowest resistance setting and start the engine. Touch a probe on the negative battery pole and the other to a bolt on the chassis. You should get at least 0.3 Ohms. If the readout stays at zero, the earth cable or chassis bolt is either loose or corroded. Do similar between an engine bolt and a chassis bolt. If the instrument doesn't register you've a problem with the engine strap.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
My earth strap doesn't look rotted but it doesn't look especially healthy. Why use bare copper at all?
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
It's not a great environment they're in and PVC's only happy up to 70C. I imagine these straps can get hotter than that.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Would this not be the same engine hot or cold? remember it is ONLY a hot engine fault.
43,351
49,594
Easiest way to test a copper earth wire is to grasp it firmly then pull and push as hard as possible.
i've seen a few which looked good but soon broke when sujected to the above.
If it doesnt break its good.
Doesnt mean the connection between cable and battery/engine/body is good though.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
I have good connection now John so we'll see next time I restart it hot (y)
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
I've had many a car over 16 yrs old (one over 20) and never had an earth strap problem. The reason I started this topic is because it seems to be particularily common to X250's
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
Did your cars have an engine compartment floor pan? Has the x2/50? My car has. It gets mentioned in every MOT as an excuse for not checking anything behind it.
Badknee
7,408
413,363
notloB
Vantage Neo
Living the dream.
I've been driving for about six months now and I've never had a problem ;) :LOL:
jonandshell
5,476
8,299
Not got one!
The strap could warm up with the continuous load of charging your battery bank. It provides the negative for your alternator remember!
Don't get these problems with Transits........:reel:::bigsmile:
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Perhaps more interestingly.
As I said the commonly reported fault is a failure to restart when hot BUT that is only on the first attempt, they start on the second go.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Fiat have a growing portfolio of problems that they try to dismiss. Recent example being the new 500 that they have conceded after much pressure from watchdog etal. Ducato scuttles still leak etc
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
Stiction. The excuse our engineering tutor gave for something reluctant to move at first attempt.
Moodybrook
802
651
Wet and cold place outside of M25
4 wheels and a pointy end
still in nappies
Excuse my ignorance but are you discussing a failure to turn over or a failure to fire up ?
If a failure to fire surely it is a fuel supply problem, in a diesel.
I've come across corroded connections never seen a mid cable failure. ? Must be a pretty historic van ?
11,956
16,571
Er ............... you should get AT THE MOST 0.3 Ohms :)
ukbill
5,501
5,274
Pinoso
4 berth low profile
although this maybe different i have had a light problem 3 times now on my van and all has been with the earth i believe overall the wiring on the fiat is sub standard
Dec 30, 2008
1,106
2,126
Cheshire
since Dec 2008 after 10 years caravanning
I read about this earth strap problem a few years back. Changed ours then for an insulated one, and its been fine.
Eric
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
and if the reading stays at infinity not zero
Zero is good! it means the resistance is lower than a cheap test meter can register.
WAG2CRU
376
495
Argyll
Hymer B654SL Star Edition
since2012
Our X250 base had intermittent problems with the windscreen wipers and cruise control, a second earth strap was the cure.
Earth problems are not confined to Fiat though, the early Freelander 2 often benefits from a second earth strap which solves all sorts of random electrical faults and improves gear changes on the auto box..
Dec 12, 2010
5,420
21,629
Cumbria
Fix It Again Toni :D
Having said that, I had an immobiliser fault on an old V40, wouldn't crank, all sorts of lights illuminated on the dash. Removed the earth strap from the gearbox and found the junction was covered in that white corrosion powder that forms on aluminium. A wire brush and smear of copper slip sorted it out.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
I'm sat here now with a hot engine and I am unable to recreate the fault so it seems to me that the reports are correct. My fault has existed since acquiring it over two years ago but because it always started second try I ignored it.
