Gellyneck
Currently travelling and noticed a few days ago the headlining above the offside "A" pillar seems damp to the touch. I've got a sneaking suspicion the windscreen seal is maybe leaking slightly. The basis for this suspicion is the headlining dried out over a couple of days despite there being heavy rain when I had the external screen covers on and pushed tight in under the luton. I'll test it with a hose later once it's dried out again to confirm.
Assuming this is the problem I'm currently awaiting a quote for removal and resealing of the screen when we get home however what's the best temporary fix pending this? And don't say drive around with the screen covers on!!!
It's a 2013 Fiat Ducato based vehicle and the screen appears to be "sat" on a rubber seal leaving a channel of around 6-7mm wide by 3-4mm deep. Given this channel it's not going to be easy to try and make a temporary fix with duct tape. Guess doing an overseal in the channel is probably the easiest solution but what sealant to use? Would guess "bathroom" type silicone is a no-no so what do the experts say?
