Window lines light scratches
Dazz
South Wales Valleys
Ford Chaussonflash02
Newbie
Hi my next job I hopefully improve the windows on my MH over the years the odd branch has marked the Hab windows so I’m looking for a product to try and take as many scratches out ?
Fenwicks window scratch remover. small bottle which works excellently with a bit of elbow grease!
Kev
Hi Dazz,
Plenty of good info on YouTube involving 2000 grit sandpaper, cutting compound and polish
Toothpaste. Had it recommended to me. Try a small amount at first on a wet cloth. Depends how deep the scratches are but worked on all my plastic hab windows.
I use autoglym super resin polish.
Can I say do not use T cut under any circumstances.
You can buy proper stuff if you want, there are recommendations on the detailing page.
My mates car just failed MOT on plastic headlamps becoming almost opaque.
He used brasso to clean them up like new
I've used Maguiars Ultimate Compound with a double action polisher - makes an excellent job without too much effort
Don’t use brasso either it’s the same as T cut.
Never had any probs polishing the caravan windows up with Brasso dubbing. Just make sure to give a good rinse afterwards.
Funny, he tried T cut and it wore his arm out without cutting the grime.
Brasso did the job in around 30 mins per light.
2000 grit wet n dry would also do the job wet.
Yes it will cut ok the problem is the chemicals will also attack the plastic.
Still horse and water ??
