But if the tracker is hidden how do you access it?Contrary to what others have said some, if not all, do have an SD card.
The sim is only to receive setting messages and to inform you if it's been triggered and where.
The SD card is to record journeys to be viewed on a computer.
The bigger value the SD the more journey data it can record before being over-written by new data.
A large SD card won't use any more power than a small one.
Unless it's a professional tracker you know where it is, you hid it.But if the tracker is hidden how do you access it?![]()
Your going to regret posting thatThanks Pappa Johnfor the clarification. Its a shame a lot of people comment giving wrong info. Then future readers will read the posts and be confused.
But your post is the accurate one, cheers
Now I understand why they spent 40 years wandering in the desert. He forgot to insert a sim card.That tracker looks very much like the one that Moses used to lead the Israelite out of Egypt when they were off to find Mount Sinai.
Yes, but did you pay 35 quid for your tracker.The positional and route data from our trackers is held on a cloud server for a 3 month rolling period and I can retrieve and view this at anytime during that 3 months time frame.
Still a current model.That tracker looks very much like the one that Moses used to lead the Israelite out of Egypt when they were off to find Mount Sinai.
Doesn't matter what it looks like when it's hidden and it works very well.
No, 28 quid.Yes, but did you pay 35 quid for your tracker.
Same size as a 20 pack of fags.You got what you paid for then.
Christ, we haven't a locker or cupboard big enough to get that one in.![]()
Can't use it anyway as it turns on the indicators.any thief worth his salt will know about the crash switch in the footwell,
They would have to realise what had been done and you could fit a metal shroud over the starter motor connections.plus cutting the feed to the starter solenoid can be over ridden with jump leads.
Yep, answer posted but ignored. He heYour going to regret posting that![]()
If you mean a tracker like the Rewire Nano it is not necessary to fit an SD card but if you do it will record location data on it. I doubt capacity is an issue but it may not like one too big. You can get a 16GB card for well under £10 now and that should be more than ample, each record is probably only a few bytes.Hi,
Wondering why trackers have micro SD cards? Is it to record a journey onto etc?
I wondered if it just pinged its location every few seconds in order to do that.
I'm using the wife's old spnaish sim that I've used all over europe before so I know it works.I'm using M2M Global in ours.
Interesting. I was going to use a 32gb one until I read your post. What is the issue with using one as big as this?If you mean a tracker like the Rewire Nano it is not necessary to fit an SD card but if you do it will record location data on it. I doubt capacity is an issue but it may not like one too big. You can get a 16GB card for well under £10 now and that should be more than ample, each record is probably only a few bytes.
But as mentioned, they are not necessary unless you want a record of a journey.
You can only try it and see if it works. The issue is when they wrote the code cards of 32GB may not have been imaginable and the result is the system can't address the whole of the memory. For example a variable might have been defined as 16 bytes but it now needs to be 32 bytes.Interesting. I was going to use a 32gb one until I read your post. What is the issue with using one as big as this?
