Hi folks I will be fitting soon a 300ah lithium battery,victron 30a charger,relay to disconnect vans split charger and 2000w renogy Inverter.
I think I want to fit an auto transfer switch to switch from mains to Inverter.
Plan is mains electric from inlet socket on van to one side of switch and Inverter feeding other then outlet then straight to the AC consumer unit.
I would disconnect the vans charger and possibly connect new charger to the mains in side of the transfer switch.also would have heating and fridge running on gas while on Inverter power.
So if this seems ok which and what size transfer switch should I look at?
Tha renogy Inverter has an inbuilt transfer switch but the power output is only a 13a socket..
Thanks Steven.
Van is a rapido with CBE consumer unit and electrics.
Thanks Steven.
