I've seen that effect on ours don't think it's smoke, more like a vapour you can see moving about in the tank, smells freshI've tried bleach in my cassette twice in maybe 14 years and both times the cassette started smoking.....so I quickly rinsed it out.
Yeah I always give it a flush down, that probably helps the cassette plastic too.I don't mind it discolouring inside it's more the bowl id be worried about ..
Hydrogen Peroxide is the answer look it up on Wikipedia and you have your answer all bleach contains it and it depends on the strength as to what it damages, what it does to plastics etc if using to sterilise use and rinse well straight away would be my answer do not let it stand in undiluted form!
Excellent, in that concentration, Hydrogen Peroxide can be used to make very potent explosivesIt's what we use for many cleaning applications here. I bought a 20ltr container at 35% strength and after 5yrs we still have plenty left....
It's a super disinfectant product and way cheaper than branded bleaches from the supermarket
Maybe best not to use it at all unless you know the type of plastic or rubber involved (manufactuer recommended )Hydrogen Peroxide is the answer look it up on Wikipedia and you have your answer all bleach contains it and it depends on the strength as to what it damages, what it does to plastics etc if using to sterilise use and rinse well straight away would be my answer do not let it stand in undiluted form!
Because 1) you are not "soaking" it in a bleach solution for long enough to remove scale, just the time needed to "clean" it. 2) The GRADE of S-S, used to make sink/drainers is resistant. Most S-S boiler manufacturers use a different grade not entirely for cost benefits, but because of other factors including the fact that Boiler can go from cold to hot with greater frequency and by implication needs to be more flexible over the longer term, without the potential for cracking.How has our 2003 stainless steel house sink survived thousands of bleach soakings/applications? It's like new.
I think you've stated the real problem. I have difficulty understanding the need to keep the inside of a toilet cassette 'clean' - more important to use an environmentally safe additive that reduces odour, helps break up solids, and assists with pouring. I use any cheap bio washing tab and Thetford's version of a SOG unit. The cassette empties cleanly - I've never rinsed one out on site ever. I clean the bowl and surrounds with Thetford's pink stuff in a spray bottle because it works and at the dilution needed it lasts a very long time.Is there not an issue with camp site septic tanks or is it cess pits ? which work by microbes breaking down the waste to an organic matter, too much bleach or Formaldehyde ( Blue) can stop that process and render the tank ueless.
If you really want to sterilise/clean your system, there are many purpose designed products you can buy. After many years I only use Bio washing capsules which leave the inside of my cassette as clean as when first bought.
What on earth had you been eating ???I've tried bleach in my cassette twice in maybe 14 years and both times the cassette started smoking.....so I quickly rinsed it out.
Hopefully this answer may help resolve some of the questions around this issue.My sister owns a company based in Tortola, BVI's : www.innua.com, who supply additives and plastisizers to the Plastics industry around the world. Short answer is: that all the plastics mentioned have additives to enable them to function in a particular role or situation. i.e. to help make vinyl soft and pliable or, as with UPvc windows, make it hard and rigid. Bleach bottles will be HDPE, High density polyethylene and single use bottles for water, PET, Polyethalene terephthalate. The latter may contain 3 different plastics ; the lid, the neck of the bottle and the thinner body.I notice whenever cleaning of waste tanks is discussed, many chemical products are mentioned but no-one ever says they use Bleach - you know - Domestos et al. Is there a reason for this. Personally at the end of a several day or week long trip, I squirt Bleach around the toilet pan and let this run into the waste tank. Not every time - just periodically. What's wrong with that. I'm only talking about an egg-cup full. Surely a lot cheaper than these fancy Blue, Pink and Green Chemicals. I do the same to the kitchen sink and grey-waste tank. Obviously i would never do this with the fresh water tank - just the waste ones. What is the problem?
