Whats Acceptable In A Floor Damp Repair (1 Viewer)
irnbru
13,518
31,151
Glasgow
Benimar 264
11 yrs
As per title. CAN a part of the floor be replaced in a modern vehicle? Would it be best to insist the damage is replaced or let it be filled with hardener?
The floor is... made up of a 6mm plywood, then polystyrene, then another 6mm external floor plywood. Van is less than 2 yrs old so under warranty.
Dec 6, 2011
11,629
25,565
South Wales
Coach built Adria
me too its a new van i would be gutted and want the van replaced.. is that a real option i dont know but that would be my knee jerk reaction to the dealer.
irnbru
irnbru
13,518
31,151
Glasgow
Benimar 264
11 yrs
No finance, we bought it used at 15 months with 1000 miles on the clock. This has came to light after 5 month of ownership.
Dec 6, 2011
11,629
25,565
South Wales
Coach built Adria
maybe an idea to look to get an motorhome independent engineers assessment. then if it was repaired i would want some form of long term warranty on the work carried out and the cause clearly identified and dealt with.
irnbru
irnbru
13,518
31,151
Glasgow
Benimar 264
11 yrs
Less than 2 years personally I would want a new floor or a new van. Is it on finance?
Water ingress coming from the roof. The walls "should" apparently dry out.
Dec 6, 2011
11,629
25,565
South Wales
Coach built Adria
WOW!
perhaps you could look for some sort of clout to use with the dealer both now and after repair.. that could be in the form of an independent report on the problem followed by a written warranty to cover all the work and extended to the rest of the bodywork. possibly independant damp check after 6 months and 12 months to ensure its not returning.
AXO66
762
4,715
Pembrokeshire
Chasson 510
How waterproof are the internal facing of the walls?
If they are non -porous how does the water vapour in the walls escape?.
Campervan_man
997
1,720
Dethleffs Globebus
Has the Motorcaravan been tested as being damp through a Habitation Check ?
How bad is the damp? High readings, visible damage ?
irnbru
irnbru
13,518
31,151
Glasgow
Benimar 264
11 yrs
No idea TBH, Its another Q I need to ask
Sorry irnbru, but for me I’d expect no damp at all.
Ofcourse we did but now it is what it is and how to go forward is the subject.
It was tested in front of the furniture that holds the damp at a reading of 9, the damp thats came to light is inside the furniture at 38%. Visible stains at flooring edge.
17,645
43,461
if sealed correctly, it "might" dry out ok and just leave a stain. Otherwise it's a major job, remove furniture in the area, strip out rotten ply, patch in new ply and reassemble.
irnbru
irnbru
13,518
31,151
Glasgow
Benimar 264
11 yrs
But a patch in job isn't gonna be as good as new or is it?
Oct 29, 2016
4,511
53,036
Surrey
Carthago C Tourer
Hi Sandra
What a horrible unexpected surprise for you to discover after only 5 months of ownership.
I hope your dealer warranty holds up for this problem, as others have said its not so much the fix, but the cause that needs to be fully addressed to stop it happening again or even spreading.
Good luck with your negotiations, hope you get the outcome that resolves everything, you dont need this in your life with such a short ownership period.
Keep us posted on your dealer reaction & suggestions,your van cant be the only one, and Marquis(main import dealer) have been quoted to have sold over 200 in the first year of roll out.
Good luck.
LES
Oct 29, 2008
5,078
5,993
West Yorkshire
If the damp is likely to have started before your purchase, then it wasn't fit for purpose. If you bought from a dealer you should return it.
53,687
150,943
That's bad news.
How has it got damp is the question?
Without examining don't really know whats caused it, maybe just a leaky wheel arch and not too serious.
But could be coming from the leaky walls, the floor is the first thing that goes on the chassis then the walls are fitted on top, damp is most likely to be coming from the walls I don't see how it could be satisfactorily repaired if that is the case.
I wouldn't have thought the floor is 6mm, normally 2 or 3mm ply.
Dec 6, 2011
11,629
25,565
South Wales
Coach built Adria
if as has been said the a roof leak is the cause then it would have to quite a serious leak to wet the wall, furniture and the floor to the extent that it has in 5 months mostly of summer OR the leak has been there for some time, is that why the previous owner changed perhaps!
citizens advice on fit for purpose advice perhaps.
May 3, 2016
2,154
20,256
Ayrshire, UK
Swift Kon-Tiki
To my mind they need to fix the cause.....
Fix or rather replace with new ALL the damage....
If it's coming from the roof, down the walls & into the floor including any furniture that has warped I doubt they will want to take all that on, SO, if they are not willing to return it to the way it should be, it simply is not fit for purpose in any way shape or form.
I tried to phone, it went to AP, speak soon.
lorger
9,674
90,716
Dumfries
Knaus Sun 650MEG
Sorry to read this Sandra, like others have said I’d expect no damp in a van that age.
If you haven’t already I’d get on to your dealer and if no joy then the manufacturer as it will still be under warranty.
Good luck
Apr 11, 2015
5,425
55,542
hull
Laika Ecovip 300
what a bummer is it one of those vans with a long manufacturers water ingress warranty?
Know you didn't buy it on finance but did you pay any of the price by CC, if so get onto your CC company.
irnbru
irnbru
13,518
31,151
Glasgow
Benimar 264
11 yrs
That's bad news.
It was the dealer that told me the make up of floor. The wall is showing no damp due to the construction of wall. Would appear water has been dripping down as per photo attached. Leak coming from under roof cap so new one has been ordered.
I agree its most likely been there prior to our ownership OR its happened while sitting in driveway, I know the water was pooling on the roof around the leak area.
Aw Sandra, I'm so sorry to hear that your new pride & joy has let you down.
Was this related to the "wet" toilet door?
You know where we are & you have our number if you need any help/support x.
Thanks, but we have never had a wet toilet door. Its Alans big bday today so will ring Hazel later after we come home from meal.
No unfortunately it was debit card.
Dec 6, 2011
11,629
25,565
South Wales
Coach built Adria
good point raised on manufacturers ingress warranty at 2 years old would be very surprised if its still not covered.
R
Robert Clark
Might be void if damp check not carried out by one of their dealers
