What to do with the bulkhead? (1 Viewer)
vantastic
69
26
Crafter xlwb
After a couple of months of doing very little I have resumed working on my conversion. Next I need to sort out the bulkhead between the driver compartment and the living area. I want to keep a bulkhead between the areas. I also have an L shaped sofa so it makes perfect sense for my layout.
I can't decide what to do exactly though. I can't decide should I leave the factory bulkhead in situ, I think this is my preferred option. But I also don't want exposed metal. I was thinking about covering it with Veltrim but I think I might want something a bit insulating under, don't I?
The other thing is I would like an escape hatch between the 2 compartments as well and with the wavy design of the bulkhead this is going to be a bit tricky too.
What have other people done? I'm really looking for ideas here.
Nov 10, 2013
423
1,096
Started in 2013
Maybe you could remove the factory fitted metal bulkhead and replace it with a lightweight ply (furniture board) bulkhead cut to the shape you would prefer.
Mistajim
22
25
Van conversion
This year
I was a bit the same and ended up removing the bulkhead entirely.
Mistajim
22
25
Van conversion
This year
Couple more pics
Jul 6, 2016
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
Any alteration to the structure of the van (removal of bulkhead) must surely be approved by the manufacturer.
I guess vans delivered for conversion (no bulkhead) are probably strenghened by an additional rib between cab and cargo area.
I don't know the answer but perhaps something to investigate !!!
43,334
49,533
The bulkhead isn't structural. Most are simply bolted in.
Sep 26, 2013
4,170
5,156
Market Rasen
Since 2003
You may regret leaving it in place after you have used the van for a while, the two best seats are in the front when swivelled round. No professional converters leave them in place as the vans would not sell if they did.
Jul 12, 2013
3,874
5,276
The City of Henlow
Adria Supreme
Since 1980
The additional space gained without a metal bulkhead should more than compensate for the loss of discreet living areas. A curtain could be installed if it was the privacy you were concerned about.
My friend hated having a fixed bulkhead, he was concerned that someone could steal his van while asleep and be unable to stop them.
Oct 2, 2008
4,475
7,961
Salopia
Duro 6x6 Overlander
since 1968
This might give the answer
17,635
43,366
just unbolt it, you will be pleased you did with the space it gives you
I know a chap that converted a luton van and cut a doorway through into the cab. He reinforced the cut edges with angle iron riveted to the thin steel edges. Quite a tidy job when finished and meant he could walk through to the drivers seat to make a quick getaway if needed without having to go outside
V
vantastic
69
26
Crafter xlwb
I hate the swivel seats so I didn't want swivels in my layout. I have a really comfy sofa instead.
I'm quite hapy with the bulkhead in place where it is. It's a 3 seater so even if the bulkhead wasn't there climbing over the seats to get to the back wouldn't be that much fun.
I thought about cutting a hole in it. I never considered chopping the top off entirely. I will have to think about that.
Have anyone come across any insulating material a couple of mm thick that can be used to pad the metal bulkhead though?
11,956
16,570
The existing bulkhead is steel and firmly attached to the outside of the van so it can conduct valuable habitation warmth to outside steel. Whatever you choose to do about access I would be tempted to replace it with non heat-conductive material.
Jan 28, 2008
10,117
18,385
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
yoga mats would be ideal for insulating the bulkhead
Aug 18, 2014
23,798
133,872
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
First thing to go when i started was the bulkhead closely followed by the double passenger seat.
Oct 2, 2008
4,475
7,961
Salopia
Duro 6x6 Overlander
since 1968
https://www.deadening.co.uk/ they do reasonable price materials
Dec 2, 2019
3,594
7,780
Amersham
van conversion
Since 2019
I have a L shape seating pulling into a double bed at the front. No swivel so I cut the bulkhead right down and built from ply half way up to have a back rest/ headboard. I used self adhesive dodo mat 10mm thermal on metal parts and auto stretch carpet on wood bits. The reminder top half, I use a heavy black out curtin. Behind the driver I will put a ply with carpet later, as the other side I will leave the curtin for acces and good visibility to look over my shoulder to the left when in EU.
Dec 2, 2019
3,594
7,780
Amersham
van conversion
Since 2019
Looks like this
V
vantastic
69
26
Crafter xlwb
Ok, so this is what I did. Cut out a bit more metal than I had initially envisioned when I started this thread but I think it works well.
still need to sort trim and curtains but I’m happy with the result
Oct 11, 2019
926
3,539
Cheshire
Converting a Van
I'm a Total Newbie!
I was thinking about having a doorway in mine, but that does look like a good idea. There would be enough room to climb over into the cab if you needed to get away. Will you have a curtain or a hatch made of wood or similar above the seating?
V
vantastic
69
26
Crafter xlwb
I'm going to install a heavy curtain. Seems like the best option. I think a hatch of sorts would just be a nuisance.
