What jacks people carrying
70s camper,Weinsberg
Just tried and need a new trolley or bottle jack, went to motorhome earlier and tried our 2 tonnes and doesn't go high enough. Forgot to measure jacking point to floor height 😳 ours lifts to about 350mm so need small light weight one with saddle extension. What does everyone use as a locator into oem holes too.
I used to carry trolly jacks, but luckily I also carry quite a stash of wooden blocks and thank goodness I do. When you’re faced with this, in Northumberland, and you live in Kent, you’d be pretty stuck with bottle jacks and trolly jacks. My only solution here, was to drag the rear up on the ramps and get the issued scissor jack under it, then by combining the blocks of wood, building up the rear and then getting the jack onto the wood, you’d be lost. Don't even consider trying to use the useless gunk that the manufacturers want to fob you off with, just so that they don’t have to provide a spare, save weight and money, as it ain’t gona work.
Posted these before, but worth a repost, especially with the topic of jacks.
Also worth a look…talks about attempting to change your wheel, in the comfort of your home, as a trial. Incidentally, I’ve arranged my belly lockers, so that the kit I need is kerb side on the van.
Don't forget when picking up a corner to change a wheel you are normally only picking up 1/4 the total weight so a 3.5 ton sprinter just round it up to 4ton so a 2ton jack should be more than capable to change a wheel
That's not the whole story. If for example you lift one wheel far enough, the opposite corner stays on the floor but the other two wheels will be in the air. So the weight is divided between two wheels, each taking half the weight. What happens in reality is that it starts off taking 1/4 of the weight, and this gradually increase to 1/2 of the weight as the suspensions of the other two wheels relax. So a 2 ton jack might get quite near its limit. Especially if the weight was not evenly distributed.
Our two ton only just lifts ours. Need a 3 tonne to be safe. Then stands.
I personally wouldn't trust a 2 ton jack. The one under the seat that came with the van is better.
You are only lifting one wheel and that no where near 2 or 3 tons so a one ton jack would be ok
View attachment 861917View attachment 861918View attachment 861919View attachment 861920View attachment 861921View attachment 861922View attachment 861923
The level ramp what a good idea
Was the only way I’d have gotten the small scissor jack in. Carrying bottle jacks and the like, just wouldn’t have fitted under it. Mind you, if that’s all I had I’d have dug a hole to start with and then worked my way up on the wooden blocks.
Upvote 1
Don’t carry a jack. Just keep the breakdown number handy. At 4.2T I wouldn’t trust the supplied scissor jack and don’t want anything bigger as payload is always at a premium.
As pappajohn has already alluded to, a block of wood, I have a 9ā€ long piece of 8ā€ x 4ā€ railway sleeper, it also saves winding the bugger up so much
We just carry the standard Peugeot scissor jack. It will just do the job, I have used it in anger. But the problem I find with them is the effort to raise the van changes depending on how low or high you start the jack. If it will only just fit in the gearing effect of the scissor makes it hard to turn the shaft, once the jack is around half way up it gets a little easier, despite the extra weight as the suspension unloads, but it also means it lifts less for each rotation of the shaft. So I use various blocks under the axke to try and keep the jack about half way up. Also gives me a little safety.
I've used the scissor that came with ours. It wasn't easy and didn't feel safe but it worked.
I used this method with the scissor jack and worked well, while utilising more blocks of wood. I’d have never lifted it with the standard tool supplied for the job.
Good qaulity Bottle/trolley jack circa &100.... E&P Leveling System.... Oh I don't know.. how about circa £2000
[/QUOTE]
More like£5000 for E&,P level system
E&P is £6k, so money cost doesn't equate.
Likewise, E&P space saving (all underslung), performance and convenience.
With the amount of forestry products being carried, multiple jacks and tools the E&P might even be lighter šŸ˜‚.
The other factor is dropping the spare and getting the flat stored away. Height and lifting capacity issues disappear with the E&P.
And I don't need a spare battery because my remote lives in it's docking station, ready to go.
Ignoring the above, you'd not find me playing in the dark with bits of wood, mud wind and rain to raise a 3.5t vehicle on any mechanical jack.
Me a 🐭. šŸ˜‚
Whilst the hydraulic levelling system is fantastic, they come with a safety warning not to use them as the sole method of ā€jackingā€ the vehicle up when changing tyres.
That's the same with mechanical jacks and other lifting devices.
