Weber Q Series BBQ Owners.. .. Hose connection ? (5 Viewers)
2,347
10,197
I'm purchasing a Weber Baby Q1000 barbie.. but don't want to use the little Weber gas cans.. too expensive to run..
If you use Calor propane or patio gas ... where did you buy the hose to connect to the regulator
Can you buy just the hose with the barbie connector on one end.. and no regulator ?
Or is it possible to connect a gas hose without any other connectors ?
and before anyone suggests, I don't want to buy a Cadac .. or any other make of gas barbie.. :)
this hose comes with the Patio gas / clip on Propane regulator .. but it's £34
725
1,577
Lancashire
We have aQ100. Have only ever used it on a normal Calor cylinder. We just bought a regulator and hose from caravan shop & used this on a spare gas cylinder. Brilliant BBQ's but agree re small cylinders, waste of time. They don't actually use a lot of gas as they cook best with the lid down which is very efficient.
Aug 29, 2010
848
1,256
Nuneaton. Only when I have to.
Hymer Exsis t564
Since Sept 2010
I have a Q1200, like the Q1000 but higher domed lid plus temperature gauge. I had a Bullfinch gas connector fitted to the van for 'on the road' and, thus, do not need a separate ŕegulator. For home use(or otherwise), say in Morocco, I have a click on Patio Gas hose plus a couple of other 28mb/37mb propane/butane regulators on hoses for odd bottles I have picked up along the way. The key thing is that the bbq has a gas hose with the male half of a quick release connector and the hose that plugs into the van is a self sealing female half, similarly for the other bottle connectors. In fact, the Bullfinch connector for the van is a 'Y' shaped 2 branch job, allowing me to hitch up the bbq and a two burner stove simultaneously. A bit of an investment in brassware but very satisfying. The Weber itself has proved to be an excellent bit of kit, although I sometimes regret not buying the Q2200. Larger output burner, larger cooking area but, surprisingly the actual weight/footprint does not appear to be commensurately larger.
Jul 5, 2013
11,731
13,711
Swap you my hardly used Q200 for the Q1200? Mine is an earlier version of the Q2200 but does not have a thermometer and has a single piece cast iron griddle. It is a bit more colourful as well - red base and white top. Cleaned it only a week or two ago and not used it since.
2,347
10,197
That's the one I've ordered .. not a bad price from this company http://www.birstall.co.uk
Try these, looks like there is a choice of regulator depending which bottle you require, or just the hose if you have a regulator.
Cheers
Ed
Thanks.. exactly what I was looking for..
848
1,256
Hymer Exsis t564
Since Sept 2010
Sorry, only just seen this. Tempting but I'm away at the moment for a while.
Jamwitt
630
367
Chandlersford
4yrs
To connect hose to Webber q I had to buy brass fitting with a spigot and nut on and I also got a bull finch connection on the van saves messing about with getting gas bottles out
2,347
10,197
I thought of that.. but it ties you to using it under the awning and as I'm also going to use mine on days out in the car will use 5kg Patio gas bottle, it can also be taken to the beach when away in the van..
of course, you could have both hose connectors.. (y)
or buy the small gas can when you cut the umbilical cord. :LOL:
2,347
10,197
That's where I got mine. Jim!
and mine arrived toady.. excellent service .. only ordered Sunday evening
and it looks like a fantastic barbie.. well made and really pleased with it.. as we have come to expect from Weber.. I now own four.. :)
can't wait to try it out.. hose connection not here yet.. but all ready with a 5kg Patio gas bottle.. :cool:
Jamwitt
630
367
Chandlersford
4yrs
Hi Jim of your many webbers have you got the small go any where one? I thinking of getting one for my van as the 1000 q is a it big ,it has to travel in the van and I'm a bit restricted on weight this one would fit nicely in my garage :)
2,347
10,197
yes.. I have had one for years.. great little barbie. I have the charcoal model,they also have a gas version.. it is a lot more compact that the Q series ..
Jamwitt
630
367
Chandlersford
4yrs
Thanks Jim I was thinking of the gas one and if I need the I got the smokey joe but a lot of places in Europe don't allow charcoal bbq(y)
Jun 9, 2022
don't own one yet
Hi i"m floundering.. I bought a Weber Q1000 and hate the mini cylinder for my gas. I've bought a proper gas bottle but can't get a hose to fit with the weber fittings. It's really frustrating that Weber sell one for £54 but I've spent enough! is there a way around this. I don't speak tech so need a simple explanation. thanks
Oct 18, 2021
2,059
6,232
Mid Devon
Adria Compact SC
Camping since 1954, MoHo 2022
Is the control valve to hose connector on the Weber a standard 1/4” L/H thread? If so, one of the Cadac or similar quick release fittings will fit (angled versions also available). You can then make up any number of different 8mm hose and regulator combinations to suit cylinders or even a direct connection to the MoHo.
Jun 9, 2022
don't own one yet
The bit that screws into the barbecue looks like this.. (first 3 images orange short hose) I bought a longer hose and regulator for a propane cylinder rather than the mini gas cartridges (black hose in image) but this new hose wont screw into the barbecue fitting as it's different
Oct 18, 2021
2,059
6,232
Mid Devon
Adria Compact SC
Certainly looks to be a 1/4” BSP L/H threaded fitting. The Cadac and other BBQ fittings to that spec will fit.
EDIT. Just seen the video that PaulC70 has posted, so you’re home and dry. (y)
May 8, 2021
1,558
2,966
Bedford, UK
Bailey Autograph792F
Since June 2021
Good video but the narrator does not appear to know that Webers are made in the USA which still uses feet and inches. That is why the nuts are not metric.
Everyones a critic :unsure: ::bigsmile:::bigsmile:::bigsmile:::bigsmile:::bigsmile:::bigsmile:
