wattage and cooker (3 Viewers)
lawrie
4
Hi,
We are looking to buy an [ame="http://www.amazon.co.uk/dp/B001LK8OTW/ref=asc_df_B001LK8OTW1628013?smid=A3P5ROKL5A1OLE&tag=googlecouk06-21&linkCode=asn&creative=22206&creativeASIN=B001LK8OTW"]Itelllichef[/ame] for out vw california.
It is 900w and I am not sure if that is ok for when we are on hook up.
If anyone has used one would also appreciate any comments.
837
289
Shropshire based
Globecar
started in 2001
Wattage & Cooker
Hi,
We are looking to buy an Itelllichef for out vw california.
Hi Lawrie
The link did not connect.
All I can say is it will draw 3.92 amps at 900 watts, so it should be ok, it all depends on your additional electrical equipment.
Hope this helps:thumb:
Nomadic
L
lawrie
4
Oh Dear,
Cannot get link to work.
It is a Morphy Richards Intellichef
Thanks for the answers and the speed they came! :Smile:
what is the usual wattage you can draw on hook up.
I guess we would have lights and radio on
cheers
lawrie
gozomike
Funster Life Member
1,001
863
Warwickshire - sometimes - but not often
Wildax Constellation
Since August 2008
Hi Most of the Hookups I have come across in the UK will supply 2,000 watts or more. In Europe it can be a lot less but you should be ok with the cooker + lights + radio, the problem could be if you try the Kettle or a heater on as well. The sites usually quote in Amps so 240 (or 230) volts * the amps they quote will give you the approx watts avalable.
golly
2,006
69,657
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
I keep a list of all the electrical items I take in the camper and how many Watts they run at ( Amps = Watts devided by Volts) ie 900w/230v = 3.91a. I make sure that the total Watts I am using at any one time dosn't exceed 3000 if on a 16 amp hook up or 2000 if on 10 amp hook up, that gives alittle bit of leeway. Don;t forget to take into account the fridge and charger.
hope that helps John
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
look at one first as at 4litre capacity it does not sound small so make sure you have room for it
43,337
49,540
Oh Dear,
cheers
lawrie
5amp (usually foreign) = 1150watts
10amp = 2300watts
16amp = 3680watts
dont forget to include the background items....charger, waterpump etc.
43,337
49,540
for the same priced you could buy a Remoska......will work on any hookup amperage..only 470watts.
or for £20 more...a larger grand remoska...650watts
Standard Remoska
43,337
49,540
L
lawrie
4
Thanks, I now have some grasp of wattage and amps :thumb:
As to Remoska, We almost bought one as they are vey highly rated.
Put off by the fact that loads of dishes need meat browning first and the remoska does not do that.
Our van is a vw and tiny. Dd not really want to be frying inside.
Unless anyone can suggest...
43,337
49,540
no browning needed with a remoska !
our first dish was roast chicken (whole).
crisp and golden skin and very moist meat.
done pork and beef with the same results.
L
lawrie
4
I went by the remoska recipe book.
If browning is not needed then that is good news :)
