- Jan 25, 2022
- 18
- 4
- Burstner solano 710
- I'm a newbie
Newbie..sorry Do I need to carry a hose to refill at sites that provide water and if so is it a off the shelf hose or a dedicated one? What length do you suggest?
absolutely agree with above.I think the answer lies in how you intend using your van.
I have a flat hose, 20 metre length on a reel which is a bit of nuisance to roll up after use but it means i can always fill up. I also carry the hozelock screw adapters for the taps with the screw fitting, useful home and abroad, just remember to remove your own when finished so i keep them in the box for the water/electrical bits needed while away.Newbie..sorry Do I need to carry a hose to refill at sites that provide water and if so is it a off the shelf hose or a dedicated one? What length do you suggest?
Very similar here, probably 20m hose and 10l watering can and water container. One in each hand seven trips from empty to full and good for me.We have a shortish blue food grade water hose, I guess its only 10 mtrs long, and the end of it with standard straight hose adaptor wedges nicely into the filler hole while filling the tank.......But! I wouldn't be without my 2 x 10ltr Red plastic watering cans, they weigh virtually nothing when empty.
I just fill as needed each day, having 2 cans balances the weight on my arms on the run to the tap and back, and I dont have to make sure all the water is squeezed out of the hose before storing it.
Fortunately we have a large garage to store these things, and I have been known to do a few trips between tap & van to get the tank brimmed up....well it keeps me fit I guess, and it saves me having to move the van.
LES
