Water Pump keeps switching on for a split second. (2 Viewers)
Craig Rogers
646
412
Midlands, UK (Welsh!)
Newbie!
About every 10 minutes, the water pump keeps switching on for a split second as if the pressure is dropping. I've checked and can't see any water leaks which would make sense. Anybody else got any ideas?
In case it was just an air lock causing it (maybe?), I've drained the system all down, so it might not do it when I refill, but thought I'd check if anyone knows?
Scotties
439
318
Hymer
Common one is the Thetford solenoid allowing water through, leave 12v on when stood up a couple of weeks and see if you get a full bowl of water. :Eeek:
capinpugwash
511
629
Hampshire
Since 2005 (20 years Caravan before that)
I have the same thing and found that the frost release valve for the hot water tank has a slight drip (a weep really).
Over the course of say 10 minutes the pressure drops enough for the pump to kick in for a second.
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Voltage low ? would that cause it?
pump seals?
Craig Rogers
Craig Rogers
646
412
Newbie!
I've just had a thought.............. I may have nudged the hot water draindown valve whilst we where away, I'm thinking that there may have been a small leak from there..........
Thanks for your help all.
11,932
9,090
Hi Craig the pump seals may be going allowing it to loose pressure :thumb: you can get a kit :thumb: or a new pump ::bigsmile::winky:
terry
11,932
9,090
Cheers all, it's still under warranty and is due a hab check soon, so I think I'll save my effort and get them to do it! :roflmto:
My monies on the pump seals :thumb: but check everywhere for leaks now,don't leave it to chance or a least turn off the pump :thumb:Wrap all joints and lower parts of any pipes in loo roll then turn pump on,leave until you are primed a couple of times then check the loo paper :winky:if all dry it is the pump.
terry
Craig Rogers
Craig Rogers
646
412
Newbie!
It's currently sitting empty at the moment, but I have my suspicions on the draindown valve being slightly open.
However, it's bugging me that I don't know, so may have to put a small fill in and watch.
I assume by "pump seals" you mean the seals on the feed, output and filter?
Nov 30, 2009
6,547
149,007
Pickering
PVC the PUG
Our leak was under the basin in the bathroom. ::bigsmile:
Ivy
We had exactly the same problem.
Ours was the outside shower hose attachment. We hunted high and low inside the motorhome .
We only found it when an icicle had formed out side. Luckily it was well below freezing at the time. Or we could still be looking for it.
spannermanwigan
392
207
wigan, lancs
since 1973
HERES A TIP
Too protect the drain down valve from being accidentally operated
I cover mine with a plastic aerosol can cap,with a slot cut in opposite
sides to allow it to sit over pipes, cheap and effective.
Allows you to store stuff around the valve without fear of operating it.
regards
Steve:thumb:::bigsmile:
jonandshell
5,476
8,299
Not got one!
We once lost a whole tankful of water when a toolbox knocked against our boiler drain valve in our old Elddis!
We arrived at a wild camping spot dry!
It might be a sliver of limescale jammed in your valve Craig.
Jan 19, 2012
638
623
Leicester
Just to hijack this thread...
...very slightly. We have had the occasional 'jug/chug/jug' noise in our new to us motorhome since we bought it. Thought at first it was the fridge starting up, but now seems more likely it's the water pump. Only happens for a split second, once every few minutes. After reading this thread, seems there may be a leak somewhere? Hadn't actually realised the system is pressurised...
I've still got two months left of the six month warranty, but would like to be certain what I'm saying before getting back to the dealers. Are there any simple tests I can do to pin the cause and problem down?
Jun 30, 2010
7,924
27,229
1992 VW Auto sleeper Mono
Since 2005 this time
Spect this is the reason take a look underneath:thumb:
Craig Rogers
Craig Rogers
646
412
Newbie!
I think it maybe the drain valve. I filled and checked all pump joints and pipe joints and they are all dry but the pump continues to prime every 10 or so mins.
Another thing I've noticed is that the bathroom tap doesn't have a lot of hot pressure but find think its related.
11,932
9,090
Do as I said in previous post and check for leaks :thumb:IF NO leaks then the only thing left is the pump seals :thumb::Doh:::bigsmile:
terry
Craig Rogers
Craig Rogers
646
412
Newbie!
Well, getting closer.
After the pump being off all night and all day, I turned it on and it primed, then about 2 mins later it kicked in for a second and then again about 4 mins later.
Checked all the joints and there is no water leak anywhere, so I removed the pump and found the following on the body that looks like there may have been some water coming out at some point;
So I stripped it all down and the diaphram is a little gunked up so thought I'd get all the rubber out and replace, but when I checked, it's far cheaper to just buy a new pump at around £40.
So, I'm cleaning all the seals up and rebuilding to see if it works first before splashing out.
If anyone is interested in what a diaphram pump stripped down looks like (the seals are shown bottom right);
It's going in for a Cab service on Friday, so might not get around to refitting it until the weekend, but I'll let you know.
Craig Rogers
Craig Rogers
646
412
Newbie!
Good news, re-assembled the pump after cleaning all the seals.
Installed, filled, primed, tested, left for 30 minutes and no re-priming.
Checked the pump and no leaks.
So far, so good. Just have to see how it goes.
haganap
12,762
26,461
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Thanks for that Craig, nice photos l I'm just about to strip down the pump on my jacuzzi it keeps putting black crap in the bath I think it's the rubber seal breaking up:Eeek:
Craig Rogers
Craig Rogers
646
412
Newbie!
That doesn't include the seals for the pressure switch which also looked like it was leaking.
All in would be close to £30 and if you shop around you can a pump for just over £40.
aba
2,775
1,112
yorkshire
dec 2009
my sister had an air bath and that had been putting black bits in for ages but its not the pump thats at fault.
it turns out that you can never get all the water out of the airway and as the bubble holes are in the bottom of the bath its an algae from the stagnant water that is always left in the air system
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Thanks for that Craig, nice photos l I'm just about to strip down the pump on [HI]my jacuzzi it keeps putting black crap in the bath[/HI] I think it's the rubber seal breaking up:Eeek:
Those dam little dogs they will crap anywhere Jacuzzi's, shitzu's etc,:ROFLMAO:
43,331
49,481
I had exactly the same problem on my RV pump Craig.
water seeping from the valve block mating surfaces and triggering the pump....2 or 3 pulses every 10 minutes or so.
luckily the pump is in an external 'wet' locker.
i had to resort to Blue Hylomar gasket cement to seal it after stripping and cleaning the surfaces.
obviously an ongoing fault as it had previously been sealed with bath silicon.
£100plus for a new Shurflo pump or £7 for a tube of cement.....no brainer really and if it last another year that £93 in my pocket
Aug 21, 2008
693
1,357
Lincolnshire, UK
Autosleeper Symbol
Help Surefow pump
I have exactly the same problem and have removed the pump and separated the two halves but can' t see how to remove the filters,there are 3 small rubber type grommets do you have to remove these to get at screws underneath ?
Thanks in advance
Alan
Craig Rogers
Craig Rogers
646
412
Newbie!
