Water filter
Carole camper
Adria 600 supreme
Does anyone know if the Adria has a water filter in the fresh water system & if so where. I’m currently away & can hear the pump but no water is coming out & the tank is 75%. I phoned the dealer but the service department is shut & the sales people have no idea!
Thanking in advance.
There is a small glass filter on the pump which you can carefully unscrew, but you may be able to see any blocking.
Have a look for the accumulator probably near the heater, and see if it has water in it. Would normally be a half to 3/4 full.
Just to he clear, when you open a tap you hear the pump... When you close the tap the pump stops?
Probably an airlock, open all the taps just a fraction in the central position and leave for a few minutes, this will often clear an airlock.
Firstly check that you don’t have water coming out of the dump valve just go outside and look underneath if it is then you need to close the boiler dump valve which will be directly over where the water is coming out.😊
Yes I can hear the pump when the tap is open
As above. Check you don’t have water coming out under the van when the pump is running.
It isn’t dumping water, I’m used to that. The water flow got less & less & stopped!
I don’t know that I can get to the pump & not sure where it’s located
Last resort. Close all taps, take shower head off and open cold water and suck the pipe.... Not joking 😁. Or perhaps your impeller in the pump is kaput?
