Water filler cap won't lock (6 Viewers)
Abacist
3,752
10,845
Devon
N & B Arto 88F Tag
since 2013
Water Filler Cap won't work
I have this issue as well.
I saw somewhere else to put the filler cap in boiling water and that this might cure the problem.
It didn't work for me!
You could try it.
movan
21,492
120,753
Moving around
Burstner
since07
I had this with last van and tried the hot water idea. It didn't work so I drove to a locksmith and he sorted it... something to do with a spring inside the cap.. Good luck.:Smile:
EthnGeoff
263
236
County Durham
Low Profile
April 2009
Suspect you'll find lots of people have had similar problems, mine would only lock occasionally but a good soak in boiling water seems to have cured the problem.
Geoff.
tonka
10,834
21,544
Cannock, Staffs
A class Burstner 800
Since 2000
As above.. very common...
Soak in hot water will free it up..
Silicon spray from Screwfix is a good investment, handy for all the locks on the van...
43,337
49,538
worth a try........
Scrape (dont shave) a pencil lead (graphite) with a craft knife onto the key.
Bit fiddly but should help get the key moving if enough lead is introduced.
You can buy small bottles of powdered graphite for future maintenance on eBay.
Graphite is the lubricate of choice by locksmiths....WD40 dries out and oil attracts dirt.
estcres
1,300
767
Sunny Bournemouth
since 2005
Several years ago I was at the Midsummer Motorhome Show at Lincoln and my water filler cap wouldn't lock, went to a stall holder and he showed me how to use it correctly and he locked it for me, I unlocked it but never got round to locking it again. It was me, it just wouldn't lock for me. Spent about 2 years travelling around with the cap fitted but not locked.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I used boiling water well over a year ago and then sprayed loads of silicon into the plastic workings. Been ok to date
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Hmm,in 4 yrs I've never bothered to find out if it locks or not ::bigsmile:
I sort of thought 'who would want to steal the water'
Am I laying myself open to the next Urban Myth-a noxious substance was introduced into our water tank and we was robbed whilst comatose :ROFLMAO:
I will check it in morn though.
Mike
17,635
43,369
same thing with toilet cassette doors, some really sad gits out there will steal anything if its not locked up, even your shit:Eeek:
MikeandCarolyn
2,170
1,468
Mike
:thumb::thumb: It locks :ROFLMAO::ROFLMAO:
Mike
43,337
49,538
Mike
once saw a 9ft tall bloke taking a pi$$ in someones tank....:ROFLMAO:
Nov 18, 2011
11,862
43,065
Planet Earth
A van
Over 25 year's
whis I had been able to lock mine sun b........d stole it last night and my gaslow cap to :cry:
Nov 10, 2012
900
8,542
Lincolnshire, UK
Just looking
I had the same problem a year ago with the water cap , it refused to lock so I bought another one which worked.
I then found out by mistake I put my old one back on which locked okay and has done ever since .
I put it down to operator error:Eeek:
sean n maggie
672
327
leeds
autotrail
just been and checked mine as never locked it before,,,,works ok though.....:thumb:
Heyupluv
3,862
1,593
France,
touring many years..42+
If it's any of these filler caps...although they look different from the outside all the same on the inside..it is a common fault they have known for years..I have had 4 new caps fitted By Rapido with the locks being changed from one cap to the other so you still use the same Key...while I was in Mayenne I called at the Rapido Factory as a complaint...they said they do not make they buy them in and yes it is a fault that has been going on for years...end of ??????BUT they said NEVER spray silicone on them or oil....it is two different materials I think Nylon...and ..Plastic/PVC and they react different at different temps...so it may lock today but not tomorrow...oops sorry no pics
Heyupluv
3,862
1,593
France,
Techno
Jul 28, 2010
15,475
20,756
May 2010
Mine is this one and the fix worked
Techno
Jul 28, 2010
15,475
20,756
May 2010
Once it's had the boiling water treatment to free the inner and outer plastic skins it needs a good dosing of silicon into the gap between. Mine has been OK through two winters now which is usually the time they stick together. A regular spray would help but I keep forgetting and it still works fine. The lock barrel isn't usually the problem
