Victron BMV, Votronics mppt communication with ARDUINO not Pi
Northampton
Rapido & Bongone
Now I know every body and his mother Uses venus OS on the the Pi, but i have played about a bit with Arduinos and also i have Votronics Mppts which i don't think will integrate with victron software. Ive seen Youtube vids that say it can be done. How does the pi or other devices connect to the BMV, ie does lead plug into shunt or display
I ran an Arduino in the bongo for 6 years just measuring temperatures all around the engine and places. With data from mine and a mates with a blown head and running no thermostat my program eventually could determine sticking thermostats open or closed and probable head gasket failuires, now thats not needed on a ducato but other fun can be had. THe most frightening event was when the AUtobox temp was 15C over temp then i noticed wife had put it into hold on 3rd, revving its nuts off.
The PI connects to the BMV at the display in my case. It has a VE. Direct port, that connects to the PI USB. The cable can be a DIY made with usb serial converter and a plug, or a victron VE. Direct cable to usb. If you look on Raspbery PI tread you find info there about this.
THanks seen the home mad cables so it looks as if i may be able to try and read the BMV. Votronics info seems to be very thin on the ground.
