valve (2 Viewers)
mariner41
23
scotland
Elddis Autoquest
3 years
Hi All
Can anyone help me with the positioning of the draining valve under the
wardrope in my autoquest 120
I drained the water off for the winter but cant remember the positioning before
I fill the tank.
I tried the manual that came with it but I'am none the wiser.
Maybe there is a web site with pictures:whatthe:
Hope you can help.
All the best
Jim.
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
Start filling, if water falls out it's the wrong way:thumb:
:Blush:I had this with our RV last winter, I was merrily filling and started thinking, mmm this is taking it's time, then was hit by the I can hear running water moment, and sure enough I'd got in a muddle and left one of the drain taps open:Doh:
Phil
226
Herts
10 years
If the handle is in line with the pipe it is open. If the handle points across the pipe it is closed.
Phil.
GJH
29,450
38,827
None, now sold
2006 to 2022
If it is like our Autoquest 100 then it needs to be horizontal to be closed. Vertical is open and will let the water drain out.
As Dodgey says, if water falls out it's the wrong way - or a bit off the horizontal.
Graham
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
Thought you'd have been in a PUDDLE, not a MUDDLE!!!!!
Dave:ROFLMAO::ROFLMAO::ROFLMAO:
pendy
153
97
Birmingham
Hi Top
3 yrs
GJH is right if it is in the straight up posion (vertical) the water will run straight out it needs to be in the horizontal.HTH
mariner41
mariner41
23
scotland
Elddis Autoquest
3 years
Thanks forall for the advice.
It works if you bring the switch towards you but
not all the way down or it runs out when you try to pump hot water:thumb:
once again thanks.
Jim
