Tyrepal solar instalation help (1 Viewer)
FJmike
972
1,046
Swindon
over ten years
Just got round to having a look at fitting Tyrepal solar and the instructions mention putting on a dustcover first, the thing is there doesn't appear to be any dust covers or space for them in the packaging. So is it OK to fit without said covers?
Wombles
10,808
11,132
SW England
A few years now
All we know is that the sensors are the same as on the TB99 that we have except that the locking grub screw has been replaced by a locknut so perhaps it's just bad instructions? Instructions for TB99 say "Remove the tyre valve dust cap and screw on the appropriate sensor in its place, but do not over-tighten. The monitor displays the pressure of the tyre as each sensor is installed." We called their technical guy when we were trying to work out what the difference was between the old & new models (other than being solar!) to see if any other improvements that would make it worth changing. Might be worth checking with TyrePal technical dept. on Monday.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Looks like it display pressure and temperature all at once
Wombles
10,808
11,132
SW England
A few years now
Good point - didn't spot that & obvious now looking at the photos :doh: Will point that out to Mr Wombles & see if he wants to spend some more money - I've been going a bit Baavet crazy & blown this months budget already:eek: but they were bargains :)
Has anyone changed from the standard to solar versions & do they think it's worth it please?
Nov 13, 2012
440
438
Somerset
since 2000
I bought the solar version at nec show it has a solar charging panel on top but also comes with a charger if needed. Fitted it and had it running in 10 min worked perfect straight out of box, cannot fault it.
Sep 28, 2015
2,018
2,615
Hymer B544
2001 Caravans 2011 Motorhomes
Thanks to Wombles I bought a Solar Tyre pal and it does display both pressure and temp together.Temp display is bit small but fine.
It's one of the best things I bought for a Motorhome. The peace of mind it gives me is tremendous. To'know' what your pressure is just by glancing at the display removes any concern that you may have problem.
Both motorhomes I've had wobble and weave a bit on varying road surfaces and this tells me it's not a flat tyre. Very reassuring, and wouldn't be without it now.Mine came with rubber covers that went on first.
Floydster
1,071
2,766
Where ever I lay my hat
A lifetime
Does each sensor have it's own solar panel or does one feed them all?
Don't the wires from the panel to the wheels get twisted up as you drive along? :D
Peter A Forbes
270
184
Rushden, Northants, UK
Mercedes 614D
As each sensor has a battery, there are no wires :) It's the monitor that has the solar panel, but you knoew that anyway.
I looked at the 6-wheel version, but a lot more expensive than four wheels. Still a good device though.
With two spare wheels it starts to add up.
Peter
11,842
14,071
I have the original version and its very good. When I saw the solar version I assumed the wheel transmitters were solar powered as I am already on my second set of batteries. Disappointed to find it's just the receiver that's solar as that only needs an hour or two charge once a month so the solar advantage is not great.
Jun 23, 2011
426
760
Pedreguer, Spain
Low profile
Since 2011
I've just bought the solar version, it came with dustcovers and the tools to fit them - haven't had a chance to fit them yet, so can't advise on that.
Puddleduck
12,386
43,995
Scottish Borders
Without at present
On and off for many years.
Like you said....... wouldn't be without the system :)
Feb 5, 2009
678
783
South Essex
15 in MH, 15 in Caravan
I think the dust covers are the little black rubber sleeves that go on the valve stems first, then stretch up & over the base of the transmitter, covering the locknut.
23,836
72,507
Peter
I just fitted them to the rear four
Hopefully I would feel if one of the fronts started going down but on the rear ( tag ) I found out the hard way that even with one virtually flat I could not detect any difference !
FJmike
FJmike
972
1,046
Swindon
over ten years
As wombels suggested I emailed Tyrepal and a set of dust shield's are on their way. I am extremely impressed with their prompt and efficient handling of my complaint.
Wombles
10,808
11,132
SW England
A few years now
Good to hear you got it sorted :)
4maddogs
39
21
North Norfolk
Low profilke
6 months
Jumping in here too. I have just received my unit. Do you havr to ensure the tyres are at the correct pressure prior to fitting? Does it then pick up the settings for the over and under inflation? At present the settings are at 17 psi on the unfitted unit!
Thanks.....probably me being dim!
Wombles
10,808
11,132
SW England
A few years now
Bit odd that it is already reading 17 psi - probably best to give TyrePal a call as their tech. helpline is very good.
Lorryman100
640
1,015
UK/Scotland
Rapido A class
Tyre pressures need to be at the correct pressure prior to fitting the sensors. The display will then show the tyre pressures usually after a couple of rotations. The display then needs to be set with the high and low pressures as it will give an annoying alarm if you leave the settings at 17psi. For example I run at 80 psi in the rear and 75 psi in the front. the low pressure alarm is set for 5 psi under and the maximum psi is set at 15 psi over. The tyres on average will rise in pressure by around 10 psi when warm which is normal. I cant remember off the top of my head what I set the temp alarms for but can find out for you next time I am up at our MoHo.
Sep 28, 2015
2,018
2,615
Hymer B544
Anyone know how long the batteries last in the sensors? My rear off side took about five minutes of being back on the Autoroute before it registered, started thinking there may have being a problem.
As I previously said this is one of, if not the best thing I've added.
Having a wider track on the rear due to the Alko chassis a bit of weaving can appear like a low tyre pressure.
Very reassuring to just have a glance and know alls well.
Lorryman100
640
1,015
UK/Scotland
Rapido A class
For me, less than a year!! N/S/R low battery icon has appeared and started flashing along with the alarm after about 5000mls. Got four new batteries to replace all of the sensors which I will do this weekend.
Oct 8, 2014
1,641
3,030
Wiltshire
Autotrail Excel 600B
Previous VW Camper + Caravan
Anyone know how long the batteries last in the sensors? .........
Driving my MH home last night the TyrePal unit started bleeping and flashing a symbol that I did not recognise. Pressures and temperatures seemed fine so I carried on and looked at the manual when I got home. It was for low battery in the Front Offside sensor.
I bought and fitted the unit in November 2014, and have covered 10,000 miles since then. However, as they are switched on by movement, their life could vary. Ordered 4x batteries today - CR1632.
treetops1
1,599
1,759
yorkshire/ lincolnshire.
Sold last van-
a long time,since 1996
I keep mine plugged in to the 12v when driving I assume the batteries charge up . Had the kit a couple of years never had problem with the batteries .Just removed them ready for new tyres getting fitted tomorrow .Dare not say how long the excellent looking tyres I am removing have being on my 2008 van lol.
Lorryman100
640
1,015
UK/Scotland
Rapido A class
The sensor batteries are CR1225. Just check the expirey dates on the battery packs prior to purchase as ebay is selling a lot with an expiry date of 2017/18.
Sep 12, 2016
2,268
5,038
Chesterfield England Tellus 3
Lunar Roadstar 800
6 years
We bought our sensors at the NEC show before we got our motorhome and got the some of the following info
The batteries last around a year according to my tyre fitter ( we had a leaking valve) so we got constant warnings
The sensors take varying times to respond we found anything from 20 seconds to 4 minutes
always set the over pressure at least 10 PSI above the inflation pressure as always as the tyre temperature rises the pressure will too
I left the min pressure at the default as you do get a sudden deflation warning anyway
Oct 8, 2014
1,641
3,030
Wiltshire
That's interesting - same size, but different temperature ratings.
Jun 23, 2011
426
760
Pedreguer, Spain
Low profile
Since 2011
I´ve got the solar unit and just had a low battery alert on one of the rear sensor come on, just over a year since purchase. The specs online say the batteries last 2 years, but when I contacted Tyrepal about the battery alert, they said that they normally last about 18 months.
The unit works really well, but coming driving back from a cold UK early last September to a heatwave in France, the tyre pressures went up by 17 psi and the tyre temperatures reached 42 degrees - at which point we stopped and let some air out of the tyres in case they exploded! :eek:
