tv cable help (11 Viewers)
ianandkath
897
1,519
spain/uk
a class
2 years
need to swap tv's in mh to freeview,need a good joiner or idea how to do this.
43,348
49,547
If your tv is located above the windscreen then I removed CRT anologue tv, cut a suitably sized piece of ply to fit just in the recess and stained/varnished to match cabinets.
I carefully measured and drilled holes to match the tv mounting holes and a hole to feed the various wires through.
I then fitted the ply to the tv then fitted the whole lot in the recess left by the crt tv.
https://www.dropbox.com/s/7r6udyti9hzza01/IMG_0054.JPG?dl=0
ianandkath
ianandkath
897
1,519
spain/uk
a class
2 years
in not good with wood, metals are ok
ianandkath
ianandkath
897
1,519
spain/uk
a class
2 years
My grandson is a joiner based in Leyland not sure how busy he is at the moment as he is starting a refurb at our village pub but I could contact him and see if you like
thanks @davanne if you could do that i would be happy,even buy you a pint or two:):)
3,057
30,823
Carmarthenshire
In between
Since 1988
I have sent him a text ....he may not get back to me straightaway as he has been busy helping with the clean up in Croston after the flooding but as soon as he does I will let you know and if it's something he could do I'll give you his number:)
