Martin Stacey
- Apr 22, 2019
- 35
- 36
- Mobilvetta Kea P65
- Since 2018
Ok I'm the second owner of this Van and my experience with the Truma Blown Air heating was the rear of the van and the washroom were extremely warm with plenty of hot air coming out the vents into these areas plus three blown air heating ducts (for mid and front of van) pass under the raised washroom floor making it feel like you have underfloor heating BUT the the vent by the HAB door and the two underseat vents at the front of the van were nowhere near as warm/hot.
I discovered that the blown air duct to the hab door area vent had a joint piece in it located under the slide out draw below the fridge. The heating duct pipe between that joint and the hab door area vent was not fitted and secured at either end so most of the hot air escaped under the draw. I have fitted this properly and also lagged it with armaflex insulation where it passes below the draw. Result heck of a lot more hot air coming out the vent.
The heating duct to the front seat area also passes under this draw and then out under the van - I have again fixed the joint properly where it passes through the floor and lagged both the under draw section and under the van section - result hey the front of the van now gets plenty of hot air and is also cosy and warm.
The usual under cab Fiat air vent on the passenger side has also now been blanked off (the one on the drivers side already had been.
