Truma 10ltr w/heater
Thame UK
boxer compass 140
A newbie solo
Hi I have a truma 10ltr w/heater it works on mains power but won’t work on gas, I’ve checked all fuses including one on pcb all ok , no green light when I turn to gas . Could this be a problem with the pcb any help or suggestions would be much appreciated cheers
do you have your 12v turned on?
Have you taken the external vent cover off.
Yes 12v on and yes external cover off
Plus I’ve checked gas supply and that’s fine
Have a look at the wiring loom that goes from the control switch to the boiler . I found mine was damaged .
It’s the grey cable with the yellow connector . Have a look at this wire and see if it’s damaged . Mine had been stappled down to the wood and had worn through the outer casing and damaged one of the wires .I had the same symptoms , no green light , worked fine on mains . I used a multimeter to find the problem . I removed the wiring loom to do this .
Thanks for the suggestion I’ll check that tomorrow, as I’m getting no power to the red and blue block next to that yellow block 👍
Did you look at the red, orange, green flashing lights ?
Depending on sequence for fault finding.
