Tips on saving weight to gain usable payload.
Oxfordshire
Hymer Exsis I 678
Since 2016
I have recently down plated my Hymer Exsis I 678. from 3850 Kg to 3500 Kg. It was a easy paper exercise via SV Tech (See other threads). When we first purchased the van in 2019 we knew we may need to down plate, due C1 licence / health issues. ( The DVLA's incompetence & delays in these matters are also covered in other threads )
Whilst I can just live with the reduced pay load it is very tight. Thus I am still looking for any tips to save weight. I am sure this will be useful to many other Funsters in the future, who may face the same problem.
We were lucky enough to be able to buy our new van to our spec, with some weight saving in mind.
With Hymer & many other makes you get a basic model, to which you add the options you require to make up the van of your choice. Most of these options add weight, thus reducing usable pay load. Clearly one's individual needs & choices will differ to others with different requirements. We could have ordered the Exsis I 588, which is a lighter base van. The 588 is a fantastic unit, but we preferred the 678 layout & are willing to make some compromises to have the van layout of our choice.
In our case we wanted the following essential things. that reduced the usable payload.
Large Fridge freezer,
Full cooker,
Solar panel,
Awning. We did not use the Hymer standard option but ordered a 1 meter shorter one to be fitted by the dealer.
Second habitation battery. (fitted by me after purchase)
External gas point. (this save the need to carry an additional gas canister for the bbq ).
There were several items on the option list we did not order. Whilst desirable were not essential.
Metallic paint, this surprisingly, adds 30 Kg to the weight.
Fog lamps.
Driver's side (passenger in UK ) automatic step.
There were several things we did order & now wish we didn't, as are not used.
Carpets
Wooden shower tray.
The one big weight saver was that we transferred the two large SafeFill gas bottles from our first van.
Given that TV streaming is now quite possible all over France & Spain perhaps we did not need the 85 cm dish we transferred from our previous van.
I have gone through all the "Stuff " we normally take with us & saved an additional 80 Kg, this included the extra table & 2 chairs. Also removed the front bed mattress & slats as this is not used normally. It is amazing how much unnecessary stuff that accumulates over time. We still have one electric bike, 2 tables, 2 chairs, bbq, awning ground sheet, tools & leveling blocks.
With all this, fully laden with food, water, dog & SWMBO we are approximately 3470 Kg, as I said before very tight.
I am going to replace the 2 x 95 Ah Gel batteries with one 110 lithium battery, saving some 30 kg.
I still need to find other savings if we can, I am thinking of using plastic bottles for wine & spirits.
I will not appreciate any one suggesting, I go on a diet to loose weight, no matter how true that my be.
We insisted that the van was weighed before we took delivery. We were lucky it was slightly lighter than we estimated by a few Kgs. We used a spread sheet to add the weight of all option items to the base weight of the van. As it happened it turned out to be quite accurate.
I appreciate that not everyone will be able or want to purchase a new van. But if payload is particularly important, you can take some of these factors into consideration when looking at used vans. You can insist the van is weighed as a condition of purchase, as the manufacturers published figures cannot be trusted & the possible number of options that may be on your particular van.
Any other tips & Ideas will be most helpful.
Youve put some thought into that.
I dont have a weight issue as just uprated and it was 19 days return from DVLA (for updated info)
We are going to try without the awning and carpets are from Dunelm atm (very light)
Less cutlery, cups, glasses plates etc so only take what you actually need.
Im totally with you on the large fridge !!
Dependant upon your usage, purchasing food (tins) to a minimum so you only have one "Emergency" meal, should give you more wine allowance on return
I would remove absolutely everything, drain both water tanks then brim the fuel tank and take it to a weighbridge, you'll then know your user payload. 20lts water is 20kg, the running capacity and don't be afraid to do this, you don't often hear about campers not being able to fill somewhere. Then repace essential items only and weigh again. We have a t-588 and I weigh it before going abroad and not had a problem so far. Our local weighbridge doesn't charge if I don't need a ticket, so I take photos of the display.
I always envy you guys with a "Local" weighbridge, saying they dont charge for no ticket, is just rubbing it in...stop it!:giggle:
Hell knows why but our council have done away with all ours, leaving only gravel pits with dodgy narrow roads in which you will probably meet a gravel lorry coming toward you.:eek:
LES
LES
I won’t tell you we have TWO weigh bridges where I work then😉😁😁😁
And I don’t pay to go on them either👍🤣🤣🤣🤣
If you've not done so already, it's probably worth having a look around some specialist camping shops and websites. Dinnerware like Corelle can save a lot of weight if you are using standard domestic stuff. Pots, pans etc. can all be bought light-weight although they do tend to be more expensive. Towsure sell a lot of stuff.
Some builders merchants have weighbridges
Most of my alcohol is in plastic and our glasses are also plastic because the racetracks I go to do not allow glass
You may be able to save a couple of kg by using a 1.5mm (16amp) 25m EHU cable instead of 2.5mm. However, this is personal preference/comfort territory, possibly relative to your electric usage etc.
There are some less crap wines in boxes now (see BIB wine club).
Cans of booze not bottles, maybe premixed G&T in cans etc.
Use a lightweight bicycle rather than electric - my hybrid is circa 11kg I think.
Reduce the tools carried
Get rid of tow bar or use a trailer for stuff ;)
LES
Have a look for scrap yards and waste transfer stations as they have them
Have you got corner steadies? I've used mine twice in 16y.
I wouldn't ditch the spare wheel, unless you are going to carry just a tyre and cope with having a long wait if you have a puncture. Perhaps you could get rid of the jack and ensure someone else will lift the vehicle if needed.
Gordon
Gordon
I wouldn't load anything for "just in case", but take a credit card instead!
When I parted with my previous van, I found numerous items that we'd been carrying around unnecessarily.
A good policy would be to take everything out over Winter (or once a year) and only put back what you need for the next trip.
Unless you’re from Yorkshire like me, take EVERYTHING in case and not to risk the credit card being broken into😉👍👍
So I removed the jack as I don't have a spare wheel. I regretted that move today when I realised that the tow-hook is with the jack and I got stuck in the mud. Fortunately the campsite warden had one, and a tractor!!
I think you may be surprised where help may come from when something goes wrong.
There's no end to being prepared for anything; you will always be adding stuff that may never be touched.
And you can be pretty sure that, when something does go wrong, it will not be in the way you were prepared for.
My Rapido had 2 tables....a large foldable one at the front and a smaller version at the rear lounge. I was surprised how heavy they were.
I lashed them both out to counter the extra weight on the full size mattress I added.
this one here and ive got to say is is very very comfy.
Amazon product ASIN B08JV5F6SR
A question here which might be daft or obvious, but does the driver and passenger count as part of the payload?
yes...and a little too much in my case ::bigsmile:
anything you add to the van, water, shopping, shelves, batteries.....erm??? yeah anything P Bentley
pain isnt it
Our last van was an Exsis i678 it was just about runnable at 3500 but very tight.
We didn't have an awning, had the TecTower oven, 2 x 14kg Alugas bottles, Snipe satellite, 2 batteries, 200 Watts solar.
We carried 2 e-bikes, spare wheel, twin tub washing machine and 2x 20lt of water in the garage as ours was a 2014 model with a tiny 100 Lt water tank.
Loaded with full tanks we were about 100kg over so we uprated to 3850kg.
I'm 75kg the boss 45kg.
We take everything out after a trip then, just pack what we need when we go away again.
That's the only bit of the toolkit I carry now. ;)
