Eribacar
Anyone either done this or have experience, most importantly can it harm it?
Thanks as always Ian
I had one - you could use a brick as a cruise control. Mine was in an Autoquest. I also had the clutch problem - unfortunately it was gummed-up input shaft splines.Thanks to all, I'll get the oil changed and add moly slip. Real problem, apart from a whine, is that the clutch cable needs adjusting, making gear changing harder, and, believe me, you do a lot of gear changing in a 2 l petrol!!
i personally wouldnt from what ive been told some parts of a gearbox rely on friction and moly might not allow this whats actually the problem with your gearbox? an oil change often helps prolong them
Synchros ?
