- Oct 7, 2019
- 55
- 114
- Fiat Duccato Sundanc
- Aug 2017
Hi everyone, I’m new although been watching from a distance but after all the help and advice I have read I’ve taken the plunge and joined.
I just have to say a massive thank you as I have completed so many jobs all by reading up on here
Fitted solar panel (110w ultra slim, mppt 75/10) Tidied cables
Replaced fly netting in hab door (sore fingers!)
Sealed a small leak on the waste tank
Taken apart and fixed leak in the Shurflo pump and replaced the filter
Citric acid treated the fresh water tank (in turn the waste too!)
Repaired the Heki mini blind (the worst job of all)
Swapped the cab stereo (no knuckles left!)
Gave the bumpers a treat with Auto Glym bumper and trim restorer
I had an assistant to help lift the solar panel up the ladder but other than that I’ve been flying solo, not bad for a just 50 female!
Two/three jobs left to do..... today I am fitting the Fitting Fiamma brackets in the wind out awning having hopefully bought the correct ones, ladder at the ready
I need a trim insert, can only find Herzim 17mm in white would like grey or can I combine this with my last job which is attaching a draught skirt.... maybe slot in a c shaped rail (all the ones I’ve seen are too narrow though)
Away this weekend to try the solar and rest!!!!
Thank you so much for all your wisdom, although I’ve spent loads I have saved loads too and made an 04 Swift Sundance look and work better
