Thetford flush overactive? solution (1 Viewer)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Does your flush spill over the back? mine did after setting the pump to the optimum for the other outlets especially the shower.
This is my solution, some plastic profile from B&Q
Some push pin rivets
Job done! works a treat.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Thanks I knew it couldn't just be mine.
I think it was about £3 for quite a long length as I used it for the additional kitchen work surface project previously.
Pushpin rivets from ebay ages ago could probably get white ones.
No adhesive used and it's a nice tight fit. To remove if necessary just push the pins right through and collect them up from the cassette housing below (cassette removed) They can be re used.
I think this problem is mainly due to Thetford's pipe only being 10mm being met by the vans 12 mm supply? thus a sudden restriction and pressure rise.
11,953
16,570
Thetford offer a restrictor for use where system pressure is high - it fits in the inlet pipe to the toilet.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Actually I think I prefer the strong flush
I just didn't want the floor washing too :roflmto:
17,630
43,340
if you cant find the restrictor, cut the feed pipe and fit a valve so you can control how much you reduce the pressure
Apr 20, 2012
428
455
derbyshire
Camper van
1year 10 times
Had this problem also put a small dob of silicone on the outlet at the top part solved the problem I thought must just be mine wish I had posted
17,630
43,340
just thinking.....turn the pressure up and you've got a bidet in the van:ROFLMAO:
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Sorry Tony I meant I could never find it for sale anywhere
However I'm more than happy with my own solution as a strong flush is preferable and it is working perfect thanks:thumb:
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
These are the rivets I had in my kit box from another job. Available in black white or clear
MHVirgins
3,889
3,158
South of Scotland
March 2011
Interesting thread.......I've thought recently that our flusher was "under-active". Even pressing the blue button for longer made no difference at all..........we didn't have this problem in our previous van which was an Elddis.
I'm wondering if there might be a bit of grit reducing the flow somehow:RollEyes:
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
Does your flush spill over the back? mine did [HI]after setting the pump to the optimum[/HI] for the other outlets especially the shower.
I think I need to adjust pump on my MH or possibility the "expansion vessel" if it has one. I fiddled with it on my last MH but didn't seem to improve anthing. Did you post your experiences in tinkering with this together with a photo trail :Blush:
2,338
10,132
Sorry and all that..
I don't like it .. it's a trap for bacteria .. and it looks unsightly, which of course is subjective..
better to have reduced the water pressure.. IMHO
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
Mine had issues and wouldn't flush err much (?) away
I pulled out the kahzi to install the Thetford electric ventilator kit and disconnected the water supply to do this. Once it was reinstalled it performed normally. An airlock perhaps?
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
With the toilet seat down it is not seen and the only water to contact it is the clean flush.
MHVirgins
3,889
3,158
South of Scotland
March 2011
:thumb:Looks like you've made a really neat job of this........no pun intended though. We're "underflushing" at the moment, will check out Sidney's advice above and try to improve things.......
Bill
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Sorry for the delay David.
I tinkered with the pump cycling adjustment screw until I had a good flow. Basically increasing run time.
page 3
http://www.shurflo.com/files/RV-Ins...assic Pump - 911-352_L_2088-422-144 _444_.pdf
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Feedback
After a few months and plenty of use I can report 100% success. Not a single drop of over spill nor the slightest indication of unhygienic deposits.
It still looks like day one.
Same picture unchanged.
Jan 8, 2014
1,038
2,519
Emsworth
Bailey 740
I need to get one fitted to me, the toilet flush ain't the problem
