Storing Crockery for travelling
Tweedie
Northants
Bailey Autograph 740
1 year (getting a bit experienced now)
Any tips for the best way to store crockery, saucepans, glasses, etc. safely and securely for travelling. We have plenty of cupboard space but no racks or holders fitted, have lined all the cupboards with anti slip matting and am looking for storage suggestions and ideas, many thanks (y)
Firstly, none of our crockery/glassware is either pottery or glass, first tip. Two reasons, in transit it all rattles and is very annoying, secondly, it could break. We have melomine crockery, and the glass substitute, the name of which is escaping me for the time being.
In our crockery cupboard there were several racks fitted, which are ideal for holding these items, I have no idea if they are standard, but they are very handy. I'll have to take a photo when I am next at the van.
We use nothing but proper cups and plates.
We use nothing but real glasses....both wine and beer.
We use nothing to protect them while driving and havent broken anything to date.....even in the caravan.
If you can drive properly theres no reason why anything should get broken.
Buy half a dozen wine glasses from Ikea and keep them in the sub-divided cardboard 'crate' they come in. Maybe take a couple out to make room for beer glasses.
We use a plastic storage box ( the ones sold everywhere, with a lid) All plates and glasses fit neatly and the box itself slides into the cupboard. It was worth getting one that fitted exactly and we now have them in every cupboard with things like the TV remote etc.
Works really well for us.
LC
If anything's likely to rattle or shift about in the lockers I use bubblewrap and/or those air-filled pouches
Bubble wrap here to, prefer crockery for tea and coffee to melamine . If left with a void to fill squash up a new toilet roll to stop movement.
I made criss-cross cardboard dividers and covered them in the soft grip-mat that comes on a roll. Each glass and mug has its own place and doesn't rattle. :)
Just a bit of kitchen roll between plates/bowls. Spare tea towels to wedge things that rattle. We use proper plates and glasses and also use some plastic boxes to store things.
We use these soft sticky mats between our crockery - works a treat
We also lined the base of all our cabinets and drawers with a plastic liner off EBay
We keep our glasses in a cut down bottle box - stops them from banging together
Hope this helps
Regards
Robert
I have Corelle plates/bowls etc. glass glasses & Bone china mugs.
The Corelle is all separated by its own bit of 'grip mat', glasses have 'grip mat' round them & sit inside each mug (we follow the French way of thinking and use small tumbler type glasses rather than tall stemmed wine glasses) & 'grip mat' round the mugs. All is then wedged into the cupboard, nothing rattles, nor gets broken!
You can put the wire racks into the cupboards for storing but it creates a lot of wasted space!
We have stacking mugs (see left of picture) - old 1970s one with plastic outer and removable Pyrex inner glass so they double up as glasses, they also stack and are very tough, we put some 'netting' rings on them to stop the glass bits clinking. We also put a 'net curtain' bar across (see lower photo) to keep contents in the cupboard and stop anything falling out when we open the door.
We use melamine plates & bowls (not the cheap plastic ones) which are placed in a storage rack similar to the below and we use either paper plates to jam them in securely or if we've used them an oven glove or something similar. The flat metal ones are good for giving extra 'shelves' for other bits too if you don't want to actually put any extra fixed shelves in, there are various types - the corner one below or rectangular ones - so you ushould be able to get something that will fit nicely in your cupboards. On these types of racks you can easily attach some elastic at the back and put a hook on the other end then pull it over stuff and hook it on the bars at the front to keep things clamped tightly in place.
Broken Link Removed
22499_1
We use a tea/coffee/sugar set that sits on its own shelf so doesnt' take up any precious storage space and is readily to hand - despite the buts not being secured (just some anti-slip mat on the shelf) they have never ever tried to make a bid for freedom!
The dish drainer is hung on the back of the wardrobe door out of the way along with a wire rack which is ideal for small bottles which you do NOT want to fall over such as soy sauce (not visible in photo).
In the garage we used a car boot tidy to put small items in, and also had an inner out of an old suitcase attached to the door itself for other lighter items which needed to be accessible, also cargo nets with hooks on are good to keep bulky contents secure.
I used to take immense care and everything was well padded, packed and in racks. It tooks ages to get it all back in the cupboard. With the new van- same layout, same cupboard- I didn't bother any more.
We have 6 porcelain mugs, in two of those stacking mug racks, stacked French arcopal plates, dishes and bowls, and glass glasses with a stainless steel tea pot and jug. Touch wood. nothing has broken and only once have we detected noise from that cupboard. That was a high pitched continuous tinkling noise and took us ages to pin down ( we thought it was the engine). It turned out to be 2 stainless steel egg cups vibrating and a tissue between them stopped it forever.
Mind it is all so wedged in that there's not a lot of room for movement.
We only use real crockery and glasses. The plate's/bowls are stacked in an ikea holder with non slip matting between sizes. Glasses in a foam holder and cups and glass bottles (of spirits) in muggis
Non slip mat on the cupboard base and paper towel between plates bowls etc and then non slip between the piles of plates and bowls, if the mugs and glasses don't touch they can't rattle.
Finally drive carefully.
The one time I let Jen tow the caravan she went very carefully over the speed bump out of the storage, front wheels over, back wheels over and then foot down, the poor caravan was about 12 inches off the ground, she made more mess in 100 yards than I have in 30 or 40 thousand miles of towing.
Martin
Correlle crockery and real glass for me. Just use strips of the non slip mat stuff from the pound shop and layer in between plates etc. glasses are wrapped in the sane stuff - no rattles and secure.
Upvote 1
We like 'real' crockery. What you may find a good tip is that we use square plates and bowls - very modern and easy to get hold of and they fit really well in cupboards as opposed to a round plate.
We have large drawers under the sink .we bought large sizes of form .from dunmils the home furnishings . Cut to fit the drawers. (We we use real pots) trace pots on form. Cut out with electric knife. its working well .and looks smart.
We use plastic stuff, the red range from places like Lakeland can't remember brand name, they are a microwave range and come with extras like racks, vented lids, plates, bowls with handles. Plastic wine glasses same as home. Inside our cupboards we put Ikea drawer dividers.
Edit called .Sistema
C__Data_Users_DefApps_AppData_INTERNETEXPLORER_Temp_Saved Images_18166_1.jpg
We also use proper china and glass. We use square plates (Tesco) because they fit the locker better, just stacked with non slip mat between, no rattles. We did break a wine glass last time away but that was while washing it, not in transit.
There is nothing wrong with melamine we have been using ours for years! And it is lighter , broken glass in a motorhome is not what you want, and they are thin wine glasses in plastic !! If that makes sense! I was given really thin glasses in Germany , I had a heck of a job getting them home unbroken.
Just put it all in the cupboards. Don't do anything special with any of it. It doesn't rattle and nothing's broken yet.
Sorry but I am unable to get on with the plastic. It may be pschycological but my occasional glass of wine or beer never tastes the way it should out of plastic.
As so many have said above a little simple packing - and believe me mine is simple - like many others I use kitchen roll.
The only breakages have been my clumsiness - sometimes as a result of exceeding the recommended dose. It just does not taste right out of plastic. Sorry, now then ....:wine:
Thanks all some great tips, plenty of ideas that I hadn't thought of.
Neither of us will eat or drink from paper or plastic, by choice.
Arcoroc glass plates and bowls transferred from the caravan to our first Moho in 2009 then to this one. They were in my Hymer caravan for 5 or 6 years then transferred to Pete's Avondale for another 2 or 3 before we swapped to a Moho. Mugs never last long anywhere with me! but I'm no more likely to drop one in the van than at home. In actual fact, since our kitchen at home has a quarry tiled floor, actually sometimes in the van they bounce but anyway - last shedloads longer!
Non-slip mats at the bottom of all the cupboards and clean T-towels stored on the top of the plate stack.
Tick VG from me too for Arcoroc/ Arcopal and Spanish equivalents. We've had them for years and never broken one item. Our draining board is right by the van door and several times a plate or dish had slid off , bounced on the van step and crashed onto the gravel outside. I suspect the fact that you see them so often in continental restaurants is not just because they are cheap but also because they're virtually indestructible.
Unlike melamine though you can warm them before eating off them and they don't scratch or stain.
