- Jun 30, 2010
- 7,924
- 27,229
- 1992 VW Auto sleeper Mono
- Since 2005 this time
Sorry! cover your "domestic" water pump, no matter how studious you drain your water system, fresh water get's left in the little clear plastic filter housing on the end of the DOMESTIC water pump, this freezes and can crack the plastic causing a leak.
On the side of your DOMESTIC hot water cylinder you will find a, generally, red plastic thingee, with a plastic tube attached that goes thro the floor, inside, is a very small, and very basic, non return valve, you only need a drip or two of water to be left in, and freeze, it will destroy the valve, so your pump when turned on will just pump your fresh water straight out on to the ground.
Sorry for not being specific last time, if you cover your DOMESTIC WATER PUMP and your hot water boiler with something , it can stop the above happening
