Spanner Light Reset (1 Viewer)
SandraL
1,373
985
Somerset
Hymer b694sl
On our 2012/13 3litre fiat there are 2 warnings to reset. A service interval and an oil interval.
I believe they can only be done via the obd socket, not by pressing pedals etc.
Software is available for 50 euros plus an obd connector.
Ours needs to be done every 2 years since we do less than 28000 miles in that time.
Multiecuscan, is name of software, but do check it works on your van and does what you want! No I havent tried it yet.
Others may be available.
Silver-Fox
9,269
29,124
Cheltenham Spa
Rapido
im a not so newbie
Too many daft sensors on motors these days.... Way over complicated
Part of the sensor problem is the idiots driving that haven't got a clue I'm sure. People don't listen to what's going on with their vehicles any more.
Plus the dealers can charge for "investigating" a problem which means profit to them.
Northernraider
27,444
177,839
On the sofa ....
Mobilvetta eurayacht
On and off since 95
Granted but some are just really annoying, I wanted to fit a few addition led lights on the front of my van wired to the sidelights but keeps bringing up a fault on the system due to the Stoopid canbus.
Need to wire them in to an ignition fed live instead as I want drl's
Old motors you could do any mods too without issues, new ones are a mare
BwB
917
1,170
Suffolk UK
Resting b'twix vans
Since 1990
I had the spanner come up and tried all of Google to find how to turn it off. All the solutions seemed to be for the previous model (up to 2007) so they didn't work. Had decided that I'd take it to a proper dealer for the next service and they would turn it off. However, after about 1000 miles I noticed the light had gone off by itself and it never did make a comeback. So, as Dave said above, just leave it and it should go away. I think I've read somewhere since that there was some ruling that as it was just a notification light they had to make it turn off after a period of time/miles :)
Apr 10, 2010
553
546
Bedfordshire
Carthago
Since Sept 2003
Ring make a variety of accessory DRLs that work from a live feed only (no need to connect to ignition controlled source) and connect to the side lights so that they dim when the lights are on. I've fitted them to two Ducato Frankias without any problem from the canbus.
(BTW, I've also fitted additional reversing and rear fog lights so they show in pairs. A dealer electrician told me that was not possible!)
Northernraider
27,444
177,839
On the sofa ....
On and off since 95
Hmm I tried connecting to the sidelights as I tend to always leave the sidelights on anyway as the go off with ignition on the Fiat.
But I kept getting a check sidelight fault on dash and the bulb would not light disconnect the drl and the fault goes away
Apr 10, 2010
553
546
Bedfordshire
Carthago
Since Sept 2003
On the Ring set, the sidelight connection is merely to sense +12v - it doesn't draw any power so doesn't affect the canbus. The power for the DLRs is drawn from the battery +12v (I connected to the jump starting stub under the bonnet) and the switching on is by the set sensing the drop in voltage caused by engaging the starter motor followed by a high charging voltage from the alternator.
DJA
Mar 5, 2011
661
1,014
A
Since 2008
Once had our 2009 Ducato serviced on its due date which was before it was due based on mileage. Shortly after we went away for about a month and during the trip the Spanner sign came on. Before we had finished out trip and after about 1000KM the sign went off.
