Northernraider
- Jul 30, 2017
- 27,416
- 177,418
- Mobilvetta eurayacht
- On and off since 95
My solar is definately not working ...despite it showing on the solar controller that 7 + amps going in ....after a full day off sunshine today not a drop has reached the batteries. They are at 12.3 volts tonight
These are new batteries only a month old, I'm losing the will to live with it I really am.
So tonight I disconnected all the wires at the controller. I've checked the connections at battery and retightened everything there. I then reconnected the wires to the controller in the following order, negative to battery , positive to battery , negative from panel , positive from panel. I'll see if it does anything different tomorrow or Tuesday and if not then something is definately not working properly. In September when I fitted the solar it was working fine and replenishing my batteries within a few hours ....since November there has been nothing ....fine perhaps in Scotland but where I am now I expected them to be working.
Because I fitted them myself I'm full of doubts whether I've done something wrong or if I've pressed a button on the damm controller and somehow switched them off I don't know but something isn't right .....im pretty sure the wiring from the panels themselves to the controller is ok but I'm not absolutely certain as the connectors are confusing due to the + - SYMBOLS on them.
I'm hoping worse case scenario it's the cheap Chinese controller that's knackered
But if so where do I get a controller here in spain?
