WANTED Solar Panel (1 Viewer)
tonka
10,834
21,544
Cannock, Staffs
A class Burstner 800
Since 2000
eBay ,(y)
Not that expensive and in my opinion better to have a new one as technically they are meant to degrade over time. See what space you have on the roof first then buy to suit your budget and the space available.
100w . £85 ..
Theonlysue
6,104
7,383
As Executive 50th an
Not long enough!
You're best off buying new. There are two types, one is more efficient than the other.
tonka
10,834
21,544
Cannock, Staffs
Since 2000
There is poly and Mono versions. You can web search and read up if you want but in my experience each can have a plus and a minus and for such small use on a motorhome not worth the worry.
Jan 28, 2008
10,121
18,390
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
wether its poly or mono a hundred wat panel will in perfect conditions produce the rated out put but one will be bigger
Jan 8, 2013
8,491
11,530
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
The difference between the types of small solar panels on a MoHo is negligible. Just buying the biggest that will fit the gap will provide a larger return. Loads of S/H on eBay, buy the 20v ones
May 7, 2016
7,266
11,760
West Sussex
Since 2003
Monocrytalline are reckoned to be slightly more efficient because of crystal purity. Might make a difference in poor light but I wouldn’t know from personal experience. I think some ebay ones claim to be mono when they are not. Mono ones are supposed to have little diamond/triangular shapes in the corner of each segment .
11,956
16,571
Solar panel output is only critical when the sky is grey or cloudy. The simple fact is that you cannot have too much panel area so the limit is set by room on the roof and the budget you allow.
