Solar panel removal (2 Viewers)
Apr 26, 2021
8
Southport, UK
Wellhouse PVC Camper
I have a Ford Transit Custom Wellhouse LUX XL camper with a solar panel glued to the roof. This panel has stopped working with no output. Have any Funsters had experience of removing a panel off the roof and if so was the roof damaged?
Jul 18, 2009
11,395
18,514
HYMER B644
Yes and yes, I had to scrape it with a heated scraper.
But is aluminium, itā€™s old and I cannot see it
I have the new panel up now
Two on Tour
10,517
52,803
Elddis Autoquest 175
Since 2010
Is it going to be easier to leave the old panel in place and fit a new panel over the top of the old panel ?
883
4,128
Wilts/Oxon border
Van Conversion
Since childhood!
Yes. Or possibly no!
My panel (and several others with the same batch code) failed late last year. It was removed and replaced this spring. However I didn't do the removal/replacement! Hence the 'no', as doing the work wasn't my personal experience. The supplier did an excellent job and you would never know there had been a previous one taken off. I was concerned that the new one would be stuck on over the old one, but that was not the case. The roof in question is an SCA 194 pop top.
Steve and Denise
5,380
14,403
Spalding LINCS
A Class Carthago
Since 2008
Best method for sika removal seems to be a multi tool with a straight blade ie no teeth on it cuts very well.
43,504
50,966
Every chance there's a hole cut under the panel where the cables enter.
The cables will then be above the roof lining.
You will have no idea how big the hole is so a new panel over the old would be my first option.
Reactions: f6c
1,280
63,676
London SE
A class Adria vision I707
since 1971
I have removed several over the years, I use a angled pallet knife with a small sawing action to cut through the Sikaflex, itā€™s time consuming but worked for me,
Obviously once the panel is removed you need to clean the roof of any remnants before replacing the solar panel,
49
85
AS Broadway EB
New
Cheese wire see Nigel Ivy's video about 3 mins in:
Terry
11,980
9,286
Lincolnshire
Can't remember ;)
Steve and Denise has given you the best and easiest answer to getting your panel off. I used to use a sharp filling knife for years then about 8/10 years ago got a cordless multi tool which I ground the teeth off an old blade using my belt sander then sharpened a edge on it. It now takes less than 2 mins and no blisters on my shoving hand šŸ‘šŸ˜‰
821
1,215
Wantage, UK
Motorhoming since 2006, 30 years tent camping in Africa
Depends on the panel and how it was fixed.
If fully flexible, probably will damage the roof - can it be left in place and a rigid placed over it?
If rigid and Sikaflex was used then itā€™s hard work but doable with piano wire (with hopefully no damage to the roof).
412
474
Gloucestershire, UK
Burstner Eliseo C602
Since 2016
I have used the cheese wire method on 2 semi flexible panels that were directly stuck down on vans with many strips of Sikaflex adhesive. It's surprisingly easy to saw through the adhesive. You then need to scrap the residue off and clean up with solvent.
Reactions: f6c
