Would this be suitable to isolate my 270watt solar panel from the controller for occasional maintenance work ? Or is there something better I should consider?
I've just searched for 'removing solar panels' but nothings come up?See the thread removing solar panels. I think you find the perfect solution
I use theseWould this be suitable to isolate my 270watt solar panel from the controller for occasional maintenance work ? Or is there something better I should consider?View attachment 459892
This is what I use also. A 30A on both panel to controller and controller to batteries.I use these
Amazon product ASIN B074RJR1JT
50 amp is probably too big for 270 watts they do a 20 as well, I think the voltage of your panel comes into it when deciding what size you need.
I see the panel as a disposable item I'm more interested in protecting the rest of the system if the panel gets damaged or fails, I think these will serve that purpose?A 270w panel its max series string 15a FUSE, and for any meaningful protection a 10a is more than enough. Make sure size of cable can take the amps. As I said, these thermal breakers will not protect a PV panel, but fine as switch.
If you got a panel or two max, as Autorouter mentioned a fuse is not necessary. When you got 3 or more it needs to be fused each one. If one fails the others dump the power in the faulty one and can burn. I had to re arrange a four string array with burns on the cells. The reason was shade on one string and bypass diodes have started to fail.I see the panel as a disposable item I'm more interested in protecting the rest of the system if the panel gets damaged or fails, I think these will serve that purpose?
Got something similar on oursWould this be suitable to isolate my 270watt solar panel from the controller for occasional maintenance work ? Or is there something better I should consider?View attachment 459892
