I have a Solar panel fitted on the top of my MH, its about 1 X 3 feet or 300 x 900 mm. it has no sign of any labels etc and if I connect a volt meter to the out put it reads 20 -21 volts on an overcast day.
I have no idea of output in terms of power but rather than connect it direct to the battery I bought a 20 amp controller which has 6 connections
two for the battery
two for the panel
two for the load
I have it currently connected to the panel and the battery and it appears to be charging the battery, the diagram seems to suggest that I take the load waires from the battery and connect then to the load terminals..
Does that sound correct ??
never had anything to do with SP before
Thans Muchly
two for the battery
two for the panel
two for the load
Thans Muchly
