Al n Val
- Oct 28, 2019
- 3,217
- 9,287
- Rapido i1090 Distinc
- since 2018
hi everyone
solar panel wiring query
i’ve just added a 140w solar panel to my 2018 Autotrail Comanche which as some of you guys may know has an existing 100w panel wired via the Sargent EC700 unit, i’ve kept the new system separate via a Victron 71/15 smart controller straight to one of the 2 X leisure 95AH AGM batteries. Now what i’m not sure about is this, the batteries as standard look like they are wired individually back to the Sargent unit, not sure why tbh, i’m thinking they must be bridged internally so it charges them both together, is this correct do you know? The batteries are not connected to each other in the battery cabinet btw.
Also do you think i should disconnect the original panel from the Sargent unit and wire in parallel or series with the new panel and totally disconnect them from the Sargent unit and connect both to the Victron, and if I were to do this would i still get the over head hab door panel readout like below or leave well alone.
I must admit i do like looking at the levels whilst its parked in storage via the My Autotrail connect method, this allows me to see everything more or less even where its parked.
cheers and thanks in advance
Al
Al
